HPI R40 Nitro Car Forum >
Old 05-11-2005, 01:55 PM
  #6586
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Page 24. Its how it looks on our kits.
So it looks like hpi has something weird on it as well. It doesnt make sense for there to be a gap on the one side. Im going to contact HPI about this and see what they say.
Artificial-I is offline
Old 05-11-2005, 01:59 PM
  #6587
Originally posted by nitroracer20
I had thethrottle trim too high on my xs3. I told you I missed somthing very stupid. I was messing with my clutch the whole time when It was just that.
Finally got to run my r40 around a little, shifts perfectly. Just need to get my gaskets and engine mount screws. I will then make the clutch engage earlier.
Thanks for everyones help.
Heh, yeah I just looked at it. The next post I answered you with check the trim.
Glad you finally checked it.
Old 05-11-2005, 02:23 PM
  #6588
yeah, Its funny. I thought I was too smart to have adjusted the trim too high. Live and learn
nitroracer20 is offline
Old 05-11-2005, 03:39 PM
  #6589
onnetz's Avatar
Default steering
Artificial-I: mine is stock and has zero slop in the steering..
I might take it apart in a little while and post a pic.. maybe it will help figure out whats up with yours..
onnetz is offline
Old 05-11-2005, 04:43 PM
  #6590
AI, I will have to check my manual tonight and see what you are talking about. When I put my kit together I had to leaving one of the plastic bushings out because the front module top piece would not screw down all the way and there was terrible binding.
performula is offline
Old 05-11-2005, 04:50 PM
  #6591
Default Bummed!
I totalled my car this weekend as I posted before. From quoting my broken parts the cost is nearly $100-$120. I feel like a chump.
The chassis is raised a tad up front (evenly across; odd, twist from the motion of the belts?): $35
Exhaust: $50
Upper and Lower A-arm: $8
Upper arm pin/rod: $5
Driveshaft: $14
Shock collar and spring $10
Rear upper link and ends: $5
Body with paint: $25
I'd hate to dip into my second kit because I'd like to sell it. Anyone ever make a huge mistake like that during their first weekend?
Old 05-11-2005, 05:10 PM
  #6592
bummer. I crashed my r40, but nothing broke except a cvd bone. I have never crashed my car that bad though.
Sorry to hear that
Old 05-11-2005, 05:27 PM
  #6593
tranced's Avatar
to eliminate the slop just find a washer that's thick enough with the proper diameter to fit in there. something like one side of a thrust bearing will work great. what i did was i took one of the plastic camber spacers and cut off the tab. works good.
tranced is offline
Old 05-11-2005, 06:06 PM
  #6594
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Default BASH A THON DAY!!
It was ON indeed. Two R40s, Rody V12 powered, one THS and other serpent pipe. One Rody 3 port std plug, other Rody 3 port turbo Roar legal. We went to Mercy college and hit the parking lots. I have a video of my R40 with rubber slicks on and yes rubbers DO SUCK ON THE R40!!!. I did 360s as fast as an 8th scale. It didnt accelerate as fast as foams also. However the stock rear foams did wear down a bit more than the fronts. Eh, it's kewl though. Gonna shave down the fronts anyway. Other than that, we had the drag race and surely my car took the lead and kept it. If he got a head start I basically stayed right with him and didnt loose pace. Door to door racing is basically how it was when I let him get a head start since his clutch engagement was late. Instead I'm sending him a setup sheet of my settings. I don't care if he thinks he will win, but I want him to get his ride setup as mine. Infact after letting him drive the car he was impressed. The car was VERY much predictable and..well just awesome. Kudos goes to me. All the days spending free time workin on the R40 pays off! Few shots. My friend has the video of everything else though. I was havin too much fun to take pics.
HarKonnenD is offline
  #6595
Rapid Roy's Avatar
Default Re: Bummed!
Exhaust: $50
Driveshaft: $14
Your chassis might actually be okay. I have 3 stock chassis and 2 of them show a slight upward bend in the front. I contacted HPI about returning them as defective and was told that the bend is a normal variance in the manufacturing of the chassis and that it straightens itself out when you put the car together. I tried installing the "bent" chassis and it did indeed straighten out. Now I'm only talking about a very small bend or warp about 1 1/2" from the very front of the chassis.
You can also try ording your parts overseas, getting the lightweight chassis. You might save some money that way.
Rapid Roy is offline
  #6596
HarKonnenD's Avatar
these are the rubbers I used. However once heated up oh man did they suck badly. I had to put the foams on again. NO RUBBERS WITH R40 IS OFFICIAL!
Old 05-11-2005, 06:07 PM
  #6597
JAG Racing's Avatar
Default Steering "slop"
I too, have some slop but it is mostly coming from all of the pivot balls at the tie-rod ends and the steering servo shaft. The small amount of play in each one really adds up in the total steering linkage. I was considering changing out the stock ball links for a better design - Any ideas?
Onnetz - I can't believe you have "zero" slop. Don't the pivot balls (tie rods) and steering servo link have some play? I am not calling you a liar- just a figure of speech more out of amazement.
JAG Racing is offline
Old 05-11-2005, 06:10 PM
  #6598
Rapid Roy's Avatar
If you are talking about the steering knuckle moving up and down on the shaft, that kind of slop won't affect the steering. Sometimes a little extra clearance is better then having things bind up.
  #6599
HarKonnenD's Avatar
Jag- Mine does have a bit of play, however with my setup the car is flawless. It doesn't affect running in straight lines or turning.
Old 05-11-2005, 06:23 PM
  #6600
onnetz's Avatar
Default Re: Steering "slop"
well maybe not zero but there is no more than 1/16" ..
my kit is fairly new also, not much wear and tear on it yet..
EDIT: ok I took a ruler and measured the play at the tire.. it was just over 1/16".
onnetz is offline
