Trinity G4 - Team Magic G4 E-Type
#1501
Sparx and impalabob, what do you guys run in the front for the drive train. do you run the gear diff or the front one way?
Thanks,
Mike
Thanks,
Mike
#1502
Ok guy's, I think I've got a deal on a new Sirio Evo 2, what kind of header, and pipe do ya recommend?
#1503
One way for me in front, Kyosho TCD gear diff filled with 30.000 kyosho silicone oil in rear. Will get my Kawahara neg diff to fit in the G4, it kinda sits quite snugly in the car right now.
Tires i ran this weekend was LRP, 40 in front and 42 in rear, that's mostly to make wearing even in front and rear.
Engine was the new Novarossi IDM 3 port turbo. Expensive but worked hella good! At this track i had a real advantage because it's extremely fast and sweepy.
Small pic of it
Trophy girls, we're not quite lucky as you americans.....
Weather was SUNNY and hot for this time of the year, around 20-23 degrees C in the shadow and 50+ in asphalt, kickin' grip with some Trackbite!
Cheers!
Small pic of it
Cheers!
#1504
Cheers!
Cheers!
#1505
hey sparx
Hey i run a front oneway, the tires i ran where speedminds 40,s all 4 corners, trued tires 58mm frt, 61mm rear ,30,000 rear diff. ride height 4 in the frt 4.5 in rear,springs blue frt,kit spring rear,shock oil,70w frt,60w rear.Eng. Rody Roem Rb12. Gears 20/52,24/47. Hey guys hve a Regionals june 4th,5th,6th any g4 drivers near the South try an come out a support ur G4 brother if u can Rc Alan where u at u hve help me more the u know buddy u r the man .
#1506
impalabob64 great job!!!! Sounds like you almost had them. Good going. Keep it up.
#1507
Super Moderator
Re: hey sparx
#1508
Super Moderator
Re: hey sparx
#1509
Originally posted by cvccsi
You will need to dremel the rear bulk quite a bit to get the neg diff rolling smoothly. (you will need to use the stock shock tower and dremel it as well) I installed one and sold it as I can't get the thing to roll freely!
My setup in short
Standard silver springs
Camber: 4 in rear, 2,5 in front
Toe: 2 in rear, 0 front
Caster: all laid back
Downstop: 3 in rear and 1 in front
Tires: 42 rear, 40 front, LRP
Damper positions: rear, all laid down, front: outer hole in both positions
I think the rest of the setup is Standard setup
#1510
..............Engine was the new Novarossi IDM 3 port turbo. Expensive but worked hella good!................
Cheers!
Cheers!
AFM
#1511
i had lil accident on sunday.
everythingwas good, the car ran perfectly, my tires were down to plastica and they were still hookin for me. i finished my last tank when my buddy with yokomo pro started to call me out. he was trying to get past me all day but didnt not have his car setup right to even run next to me. i figured wat the hell let me fill up last tank and show him wat g4 is al about AGAIN. few laps later im ahead when im coming into the sweeper from the straightaway, my car somes into the turn and takes off full speed, about 50 feel later it hits a curb.
make a long story short my wire on the batteries came loose and the car took off. the chassis is bent in 3 places, case for 9402 servo is broken, universal is slightly bent, tanks just cracked in half, and front bumper is lil messedup. amazingly no plastic is damages, nothing is cracked!!!!. i just fiinished ordering spare parts , lots a $$$ . I was planning to go to Connecticut this weekend to race but looks like that thats not goin to happen. .
#1513
Brooklynrc- Bummer sorry to hear that. Was it a 3mm or 4mm chasis? I don't know if you ordered your parts yet but I might have a G4 roller for sale HOPPED. I'm not sure but I might be getting another car. It might save you on cost!! If your interested PM me.
#1514
Originally posted by afm
Novarossi IDM?????? What engine is that??? where can i see one?? Web page or reference???
AFM
AFM
Some sites i've found with it
Spanish site..
German..
The price i bought it for is around 400$ if you go at the daily rating, 3700SEK
It will probably be cheaper in the US because you don't have these ridicilous prices we have
#1515
BTW, new bodies painted!
