Kyosho VoneR Thread
Originally posted by kewdawg
I did just that! Maybe, i'll try the 3mm machine screws. Can you use the o-ring that comes with the aluminum diff, on the stock diff? If, so, what's the part number?
If your going to use 3mm machine screws, make sure you drill out the holes to 2.5mm otherwise the plastic distorts and may make the leaking worse.
I don't think you can use that "O" ring with a standard diff and you shouldn't need to.
We use "Stag" non hardening gasket goo - that brown stuff. I found the oxygen safe silicone tends to disolve somewhat in the diff oil but the acetic cure stuff might me OK.
Also, don't overfill the diff - just covering the cross shafts is fine.
For the parking-lot track, start with the box set-up. It's pretty good.
Originally posted by roadrage
well im sure he wants to no when in america
Location: Cebu City, Philippines and Ocala, Florida, USA
which pulley???
Originally posted by boner
Joop: look at your manual on the optional part listed at the back, you can see list of the spring listed. Silver - soft, black - medium, gold - hard. Than there are other springs that are color coded, these spring are over lap the original 3 spring choices. They offer more fine tuning thru spring.
Doki: V1RR manual suggested 25teeth pulley (over drive) with 1 way.
Originally posted by Taylor-Racing
kewdawg,
kewdawg,
Is there a brand name for the brown "gasket goo"? What foams would you recommend for the box set-up? Thanks for the info.
Permatex also makes one that is similar.
It's impossible to help with the foams without knowing your track and the conditions etc.
What do others generally run there?
hey pplz
is it true u can convert a v one s into a RR
thanks
thanks
hey
i also need the part no for the v one R clutch and V one RR clutch
thanks heaps
thanks heaps
v-one s to v-one rr
Originally posted by MRWRX_69
hey pplz
thanks
hey pplz
thanks
v-one s to v-one rr
hey pplz
thanks
hey pplz
thanks
"Stag" is the brand name.
hey
thanks heaps
hey
thanks heaps
hey
thanks heaps
hey
thanks heaps
it's possible you have the idle stop open too wide. Also check the spring retainer nut make sure it didn't backed out.
Are you guys doing anything different / extra, when you built the Centax clutch?
