Kyosho VoneR Thread
#9166
Originally posted by Taylor-Racing
Have you tried Active's?
If so, how do they compare?
japanese, italy, USA. so, dont bother to get that far for active tires.
#9167
Originally posted by Manticore
we have plenty of choices here !!
#9168
o'donnel engine !
#9169
Rumour has it that the ODonnel engine is manufactured by Thunder Tiger.
#9170
Originally posted by tl2111
Could you kindly share with us as well??
Main things I changed from EVO stock setup.
Droop, removed a small amount front and rear (stock is 0 and 4).
Light Blue springs all around.
42/40 front and rear tires (for Brendale) 59 front and 62 rear diameter.
Front swaybar 45 degrees rear Gold bar with adjusters moved all the way in.
50,000 wt in rear diff.
12 pitch steering arm.
#9171
evo conversion on order,but will the v one r front diff work on the new car? read some were that said front one way was of a different width, is this true.
#9172
Originally posted by AMGRacer
Sure I can
Sure I can
How is the traction when you run this setup, seems to me you need lots of turn in with the your front setting. btw what shocks oil did you use?
#9173
AMG
AMG
During this testing I remained with the 50wt shock oils
I am not pretending to be the fastest guy at Brendale, but the car felt pretty nice to me!
#9174
#9175
Traction is good! In fact too good in the rear the car would not rotate which is why I used 50K in the rear diff.
#9176
o'donnel engine !
o'donnel engine !
I'll try to do a search at yahoo for these
#9177
Originally posted by coolracing
Nice . . any more info on this manticore ?
#9178
My tyres seemed to be coning outwards... what do I do to rectify this? More or less camber (i'm guessing less).... I'm pretty sure it's at 2 degrees at the moment. Then again... I was using the 35 Shore tyres, whether that has anything to do with it .
#9179
i think you dont need to worry about how much camber you run as long as your car runs great. see how much rear camber the 1:1 race car has when talking about 1:10 scale speed is much higher thru corners.
#9180
Is there a FW-05 thread or do you chat in here about that car?
Cheers
Cheers
