Kyosho VoneR Thread
#1651
Re: Where is everyone?
Originally posted by Nemesis
You're right Mauler, this site has been dead lately.
#1652
Hey Art how was the race at Castle if ya wen't
#1653
Has anyone snapped there 5star universals when the hit a board or pipe, I broke 2 over the weekend wile practicing
I have a therory as to why but need to hear other stories and there cures, I do know the #1 reason Don't hit anything but yea right.......like thats gonna happen
#1654
#1655
Originally posted by adelmundo
Actually I would need to buy 2. One is for my great uncle (grandfather's brother) who is disabled due to a stroke and he can't grip like a fist with his left hand so he can't use a pistol grip, but he can move the left stick with his thumb. The other hand is OK. I want one for myself just to try it for the heck of it hehehe!
#1656
racing maybe?
probably racing away or waiting for world cup to watch
I been seeing quite a lot of activities in Mugen thread and not much here!
Anyone got any idea why kyosho site are designed such horribly? They don't seems to bother to change their web site design for so long! and it is unfriendly to use. Well, maybe they should take a look at Mugen or other web sites for feedback.
V-One R or RR or even S is a good car, but their manuals are no where to be seen in their web site. Not like Serpent or Mugent.
Just my 2 cents.
Just my 2 cents.
#1657
large number of broken universals in the front of V1-Rs running
the 5 Star universal/cvd at Castle when they slap the boards.
The usual brinnell number (hardness measurement) for axle
shafts, dog bones and universals is approximately 30...Yokomo
used a brinnell number of 60 for their original axle shafts in the
GT-4 kits and they would snap off from just tapping boards...
I notice the same phenomenon with the 5 Star universals....
#1658
Thanks JD I didnt know that, I do wish somethings for these little cars where as strong as a grade 8 or 10 bolt
You gonna be at Delta this weekend if it doesn't rain? Need to chat with you in person again
#1659
Which is lighter, the stock plastic pulleys or the Kawahara Aluminum pullets for the V-ONE R?
#1660
This might interest you too... I got to know that Team Kyosho have their own range of aluminium pulleys and they are known to have worked well with the V One R. Right now, if I'm not wrong, the whole of Japan is out of 18T the last time I enquired...
If you want to increase the efficiency of your drive train further, try the titanium front layshaft and 2 speed shaft from Square... of course, you can't do without the SP belt...
#1661
FYI, my Kawahara mid belt pulley (front) fell apart after two days of use. The ring which retains the belt on one side fell off and launched the belt.
#1662
So can someone post ALL (I mean ALL) part numbers to convert the V-ONE R to the V-ONE RR. So far this is what I have:
VZ090 = Centax Clutch
VZ088 = Body Mount post
VZ083 = Rear Body Mount Parts
VZ082 = Front Body Mount and Wide bumber parts
VZ080 = Dogbones for the V-ONE RR Rear
VZ070 = Side Belt for Overdrive
? = 25T Overdrive Pulley
? = Transponder mount next to throttle servo
? = New mounting parts that replace the ball and cups to mount the shock on the Suspension A arms
Is there anything else I missed? Can someone give me the part numbers for the ones with a ? next to it as well. All info would be GREATLY appreciated.
#1663
Originally posted by Mauler
I did not weigh it myself, but a respectable driver from here told me that the aluminuim pulleys are slightly heavier... but in terms of transmittion, the aluminium ones are way more efficient then the stock plastic ones...
#1664
Originally posted by AMGRacer
The Kyosho V1RR comes with a completely new set of pulleys which are made from the graphite infused plastic. In my opinion this should transmit the power as efficiently as an aluminium without the weight. JMO.
Other than the rear composite pulley from kfactory, anyone tried others? Or am I the only one having this problem?
#1665
