Xray NT1
#5777
Last year the NT1 EC (European champion out in November 2009) had been remplaced by the NT 2010 in the begining of the year 2010.
I think that xray can do the same thing in 2011.
#5778
IF there is a change it would be minor things like MAYBE a clutch shoe, brake pad change. But since the Worlds edition still has the original brake pad I don't see them changing anything anytime soon. The EU tracks aren't usually treated with traction compound which is why they have kept the white shoe in the stock kit for so long. There aren't really that many deficiencies across the board with the 2010 car. Consider the differences between the worlds car and the 2010 car, not many other than weight distribution/ light parts which would likely remain option parts... Note there were a couple 2009 cars that didn't get revised since they were competitive as they were. XB8 etc, I think this time around its the NT1 that stays as is unless they come to a conclusion on brake pad, clutch shoe or something like that. I know Martin is very happy with the car.
#5779
New Arrival DLS on NT1
#5780
Guest
Steering Servo
I just picked up an NT1 and was wondering if my Hitec HS 945 MG steering servo is sufficient enough for the car. The servo has 152.8 oz-in @6.0V and 122 oz-in @4.8V. Also it's .12 sec. The car wil be running foam on medium bite concrete track that's 125x100...roughly that size. If you guys think the servo isn't sufficient, what do you guys recommend for steering servo. Thanks
#5782
#5783
CSO Release new product again !
64 Titanium Rear Dog bone
#5784
Cheers
#5785
KO PROPO RSX Servo had top speed !
#5787
#5788
Guest
Swapping fuel
Question: If i had a motor that was broken in by brand X with 20% nitro and I wanted to switch to brand Y with 30% nitro or vise versa, do I need to repeat the break in process again?
#5789
no,just shim the motor right,and richen it from the start.
then tune from there.
#5790
Guest
