Serpent 720
#2161
Originally Posted by ianhobbies
FRIDAY NIGHT RACE WITH MR JULIUS KOLFF
AT JP RACEWAY PHILIPPINES MARCH 16 2007
HERE'S A PREVIEW
http://www.dailymotion.com/ianhobbie...way-mar-16-200
see you at the next race julius! thank you!
from all the guys at RCMP
HERE'S A PREVIEW
It's Meister Kolff!
#2162
cone washer
Anyone know where the cone washer that comes with the 3rd one set goes?
I'am not quite sure where to install it. Behind the brake rotor?
Second question. Is there any reason to run the overdrive front pulley with the 3rd oneway.
I know these may seem dumb questions but my experience is with 1/8 buggys. Kind of new to onroad 1/10.
#2163
The cone washer goes inboard of the bearing that is next to the gears. The cone should be pointed at the break disk. Be sure to lube the bearings in the one way and use lock tite. The hardest thing was to put that snap ring on the bearing/break carrier.
Check with the instructions by going to Serpent.com . When there, type in the part number and hit downloads from that part number. There is a good schematic on how to install the part.
#2164
Thanks ghettoteacher I didn't know those instruction were there like that.
Learned something there.
Anyone try the overdrive kit?
#2165
I know someone asked if the 3rd one way will fit the 710, but I don't recall seeing an answer.
Will the 3rd one way fit the 710?
#2166
Serpent and Maxy's Fuel (Make Clean Sweep) - Florida State Race in
Port Charlotte!!!!!!!
Congrats Danny (sedan) and Paolo (1/8)
#2167
Wow Danny! That makes two in a row. Awesome!
#2169
#2170
#2171
Originally Posted by B4
I would check the drawing again if i was you. The cone is pointed towards the outside of the car so the flat part is next to the brake disc.
#2172
congrat's to danny for that too in a row with the 720
paolo what do i say you are on fire right now keep it up
#2173
I quess the overdrive kit is a secret. Is it a taboo subject or what?
#2174
#2175
Rainer, getting a 720??
