Serpent 720
#2911
Probably 960... I will be pitting either Gianni or Dj. in sedan. I also dont own a sedan.....
Rafael
Rafael
#2913
Need Help
Can you guys please suggest what is wrong with my setup. Chasing rear end grip exiting corners (on throttle). I've had this problem for a while, we have a low grip track.
Things i started with today
18T mid (swapped the 21T and 22T around)
Trued the tires for a 3m split
Yellow springs front and rear
80,000 front diff
30,000 rear diff
Front and rear roll center standard
Rear 3deg camber 3deg toe
0mm front droop
With this setup the car was very taily on the exits and i was losing lots of time.
Changes I made during the day to try and solve the issue
Lowest roll center blocks on the rear
rear camber at 3 but changed toe to 4deg
changed to 37sh rears
reduced the clutch gap to soften the initial bite
1mm front droop
10,000 in the rear diff
The car was better but nowhere near what it should be.
80,000 front diff
30,000 rear diff
0mm front droop
1mm front droop
#2918
can the suspension tweak of the car be effectively corrected using method in the booklet even if the car is not yet balanced (left - right)?
#2919
CONGRATS!!!!!!!!! to Serpent and Maxy's Fuel. Both won all four of the Summer Series races for sedan and took the overall points. Races were held between the Fort Myers track and the Port Charlotte track, and with three different drivers having wins. Congrats also to Luke W. for the points win.
#2920
Hello from France,
here's a little report I made on the 720-07
http://www.yome3000.com/forums-lire.php?id=6832&f=4
iwill upgrade it regularly.
Enjoy
Enjoy
#2921
Hello from France,
Enjoy
Enjoy
#2922
Serpent 720 Parts
Just findout othe hk online shop can support the Serpent 720 Parts.
not only the mushroom now!!some items little bit cheaper!!
http://www.rc-union.com/index.php?cP...88_736_737_761
#2925
Just wanted to say thank you to Serpent USA for the great product. This weekend was the first round of the Florida State Series. Weather as scary all weekend, but we were able to get in all of the qualifing and some of the mains. I was able to take the TQ. Not able to run the mains allowed me to take advantage of the good qualifing and take the win.
Thanks to Poalo for the winning product and to Ashton for the pitting!!!!
Aslo thanks to the Port Charlotte crew for the hard work this weekend in working with the rain.
