Jammin X1 - so close yet so far
#2867
the medium red is still the best spring for x1cr. chad using mugen grey because it suited to his driving style. taylor and almost everyone found the red to be just right for everywhere. almost 90% on podium finish using medium red spring.
so it all depends on driving style..as ChadB indicated for himself. i use softer blue spring. we got the "bumpiest" track ever...
#2869
u got point there....mate... but u have 2 bring a few preloads to tune for everchanging track condition. what happen if the right setup is half of the height of yer preload? then i guess u just use 2 preloads then... or cut it half, right? while others using threaded shock..just turn. and in offroad, preload can & will pop out...and it will pop out on the left only or right only..then u have an unbalance shock setup... while threaded shock will stay the same.
oh well, u got unthreaded shock and u happy.. so why change, right.
#2870
Who cares if they are threaded!!! Threaded shocks are a pain in the butt, I prefer unthreaded just because it is easier to adjust them with the exact same preload without needing to measure them every time.
#2871
Season Greetings
Greetings and compliments of the season and a happy new year. May 2007 bring you guys lots of success and lots of RC racing.
I have been doing some testing and maintenance on my cars. Also decided to race withe the Go21 engine. I am now running the Go21 7port in my buggy and truggy. I must say my truggy has never looked this good since I bought it. This engine with a JP1 pipe 13T CB and I give the Mugen truggy with C6 a run for his money. I have a 250ml tank in my truggy and get easily 14+ min on a tank.
I have been trying some different setups. Our tarck is very bumpy, rutted and loose. A very chalanging track.
I used to run 5-7-2 diffs. I have tried 5-5-2 and the buggy feels very loose and on its own mission. I mean it seems you have to really drive with more concentration. I prefer 7-7-2. It seems much better on power in the turns and also the 7 centre gives you that control. I noticed the thicker you go in the centre the more control you have of your buggy. ie wrt acceleration and braking.
Also a good tip. HN released the shock spring socks. I have been using it and its definitely a must to jammin riders. It keeps the shocks and springs free from dust and dirt and more consistent throughout the race.
#2872
what do u mean the HN shock spring socks??? is it new? any picture?
#2873
Greetings jfc_tech
Here is some pics.
Here is some pics.
#2876
#2877
thanks for the tip man. im new to buggy. i installed 5-5-2 oil after experienced racers told me to do so, but if i find it is still loose i will give a go with 5-7-2
To get 7k mix 5k and 10k 50-50
To get 2K mix 1K and 3K 50-50
#2878
http://www.gesilicones.com/gesilwiza...l?SMSESSION=NO)
use this to determine the correct ratio of diff oils. very helpful.
#2879
Originally Posted by macnkitty2002
get outta here if your going to bash threaded shocks. listen to what JFC said, you have to carry around so many preload spacers, and even then you will not always have the exact preload you want without cutting them. they don't gurantee a preload hold because the spacers could pop out too. and if someone thinks measuring them is a pain, try using allen wrenches or simply pull out your handy ruler. twist and go! i know, Mugen and Kyosho both use non-threaded shocks, but they don't know what they're missing!
#2880
I currently own a FT jammin and was just speaking my opinion on the matter. I have never had a spacer pop out and how hard is it to carry extra preload spacers in the pit box anyway? Or do you just grab your buggy, controller, and starter box strap them to your BMX and pedal to the local track. As far as Kyosho and Mugen not knowing what thier missing, I can only tell you what they are not missing and that would be vacant space in thier trophy cases from all the World and National championship trophies.
i believe Mugen and Kyosho still use non-threaded shocks because they don't want to mess with what they have used to win world titles. however, as AE did with the GT2, Mugen/Kyosho need to step outside of the box soon and realize the potential gains by using threaded shocks.
with that being said, this case is closed.
