Old 08-16-2008, 10:54 AM   #31
Originally Posted by Bigedmond View Post
That is the reason i stopped running OS motors. I had 3, 2 vspec and 1 speed get the crack in 1 piece motor mounts.
I am surprised now one mentioned an obvious possibility. FUEL. you live in AZ, as i live in NV. the heat were we live kills fuel.
When you say "kills fuel" are you meaning to relate that to how the case cracked? Just curious what you mean so I can try to prevent it.
-Don
Don Duct is offline   Reply With Quote
Old 08-16-2008, 11:32 AM   #32
He wasn't saying fuel cracked the case. Fuel lefted out in direct sunlight and high humid makes the fuel draw moisture. Another thing dump the temp gun thats fine if you wa starting out in nitro. But by now you should be able to tune by sight, sound, smell and reading the glow plug.
pdmustgt is offline   Reply With Quote
Old 08-16-2008, 11:46 AM   #33
Ah... ok. Actually I knew that about fuel. I keep my fuel in a cooler just to keep it out of the sun and somewhat insulated from heat.
And thanks for the tip about tuning and I will take your advice. Actually I learned A LOT though this process. I was able to learn and observe several great engine tuners and none of them used the temp gun as you meantion. I learned how apply techniques in tuning as you describe. Now I just have to practice it... once I get my engine back.
Thank you,
-Don
Old 08-16-2008, 12:02 PM   #34
Bigedmond's Avatar
Trader Rating: 18 (100%+)
Yea, i was just saying that heat can kill the fuel.
Cracking blocks are the reason i stopped running os motors. I mean, almost nine hundred bucks of motors rendered worthless because of a block crack inside its first gallon. Sure i can ebay new blocks, but they will just crack to. So i switched to GRP. Orion is the next motor on my list to try out.
Bigedmond is offline   Reply With Quote
Old 08-16-2008, 12:46 PM   #35
What do you think of Novarossi or Gotech?
Old 08-16-2008, 01:53 PM   #36
Novarossi engines are fantastic. Go's seem to have widespread tuning issues. Just my two cents. I've experienced the headache of a Go motor and it was enough to scare me and everyone else who tried to help me off.
Semple is offline   Reply With Quote
Old 08-16-2008, 02:23 PM   #37
David Day's Avatar
Send a message via AIM to David Day Send a message via MSN to David Day Send a message via Yahoo to David Day
Novarossi engines are excellent, Definately recommend them
From what I hear about OS Engines, I will never even think about them again, :P
Day Brothers Racing
*http://daybrosracing.webege.com*
2nd Place 2006 Winter Series 10th/Scale Gas @ Lake Havasu RC Raceway
RC10GT - Snoopy #5x
Kyosho Inferno777 WC SP2
David Day is offline   Reply With Quote
Old 08-16-2008, 03:03 PM   #38
Thank you,
-Don
Ok, you know I wasn't trying to dump on you about the temp gun.
Thats great you are learning
Old 08-16-2008, 09:03 PM   #39
Oh ya... I assumed you were not dumping on me... I don't take anything offensive in forums because it's too easy to read too much in to words.
Also, you’re right on... I did think you used temp guns more in tuning, but now I know it's very much the opposite. It seems the only thing you use a temp gun for is to just make sure your not burning up your engine due to lack of tuning knowledge or as a tool for breaking in engines. I now know temp guns have nothing to do with actually tuning your engine.
Thank you,
-Don
Old 08-16-2008, 09:59 PM   #40
bgbelden's Avatar
Originally Posted by cheesecake View Post
dont bother with anything else just replace the rod and i bet your problems will be solved. when the vspec rod gets slop it causes the engine to flame out. replace the rod seal the backplate and you should be good to go
I've been having same issues and my boy said that my con rod was prob shot.
''Life's tough ........
it's even tougher if you're stupid..''
-- John Wayne
bgbelden is offline   Reply With Quote
Old 08-16-2008, 10:13 PM   #41
houston's Avatar
Trader Rating: 91 (100%+)
definitely novarossi!!!
TEAM FUSION X ENGINES / TEAM BYRON ORIGINALS / TEAM PROLINE RACING TIRES / TEAM SICK GRAPHICS /TEAM KYOSHO / things I support: COMP HEAT DEALER /TEAM LUNSFORD/ FUSIONX™ USA / TEAM KYOSHO / "H.E.S."™ / BYRON FUELS / RC-OMGUSA/KICWEBDESIGNZ/AKA TIRES/PROLINE RACING TIRES /RAYA RACING/BUKU POWER CLUTCH/M2CRACING/special thanks to STAV and JIM HOTTIGREENMOUNTAINGRILLS.COM
houston is offline   Reply With Quote
Old 08-17-2008, 12:16 AM   #42
Bigedmond's Avatar
I personally have never ran a Go Tech, or Nova. I have nothing against them.
I definitely agree, that using the temp gun should only be used to verify what you see, feel and hear. at my track, we have a father son team, and they only tune by temp. I have tried, along with others trying to get it across to them that temp should not be what they go by.
I think one of these days i am going to write an extensive blog on engine tuning.
Old 08-17-2008, 12:33 AM   #43
David Day's Avatar
Please do
Day Brothers Racing
RC10GT - Snoopy #5x
Old 08-17-2008, 01:35 AM   #44
Registered User
RB bud!!!
Loop&Roll is offline   Reply With Quote
Old 08-17-2008, 04:11 AM   #45
mremtr's Avatar
After seeing a GRP go last night , I would definately say they RIP !
they will run with a OS all day long , both on milage and down the straights!
As for the Ex-Tech ...... I am not impressed ..... I have yet to see one that will run with a 421B Nova or get over 7 minutes on a tank! This is a big issue now a days, and you need to get the run time out of them. I run 6 minute Quallies with a first lap run to the line so you need to get at least 6:45 run time ! And they still run out of fuel ? OS and GRP easily make this window, and a properly tuned RB C6 will , but most others are cutting it very close.
mremtr is offline   Reply With Quote
chronic header bending problem omega_revo Monster Trucks 1 03-04-2006 01:53 AM
XXX-S cut outs TL_XXX-S_racer Electric On-Road 9 09-25-2004 11:00 PM
Dissapointing turn-outs The Buster Wisconsin & Illinois Racing 11 07-28-2004 10:02 AM
The ins and outs of motors..... RoadRat Electric On-Road 2 05-26-2003 12:43 PM
Flame outs,,, My MT-12 is driving me nuts!11 compuatic Nitro On-Road 13 05-12-2003 01:24 AM
