Inferno MP9 thread
The old engine mounts are taller and is another method for preventing contact between the clutch bell and chassis. The old mounts also have a smaller footprint and allow you to use locknuts on the bolts that fasten the engine mount plate to the chassis.
It really helps with the flex in the stock chassis and even in the hard version chassis. I have it on 2 of my 3 k cars one chassis each and I absolutely love it! The price might be a bit high to some but the king headz is even more expensive since you need the entire kit.
I just put a new bell on a different engine and will test it in about two hours and will tell you if there are any marks on the bell to confirm but from what I have seen in testing and the reduced flex I am going to say NO need to drill the chassis. Again I will confirm this later.
I could be wrong as I'm only going from what I've seen in the official pic of the part.
Most likely someone would actually need to use the thing to answer your question and guessing that since it's only just gone on sale, very few people would have had a chance to buy it, let alone take delivery, install the part and the test ther car with and without the new brace.
Haven't seen Tebo or King or any other top pro K drivers using it, so maybe it really isn't all that necessary in any case?
I agree 100%. And both of those are definitely CNC'd and almost definitely would have far greater resistance to bending and hence would be far more effective than the Kyosho part. Wonder why it is that none of the top MP9 driving pros are using it?
No I don't think so it's social media or nothing
I've uploaded one picture especially for you aaron125 as about 10% of the car is left from the one I got off you 18months or so ago
Do you guys replace the universals when the pins wear out, or are you buying replacement pins?
I have been having issues with my clutch backing off. I have been running Orion engines and had this problem every couple of weekends of racing. I just just switched over to an O.S. Speed Spec II. I had the same problem yesterday in my first day racing the O.S. I am using the Kyosho collet that comes with the kit and thinking that might be the problem. My thought is that the collet is not the right size and is allowing the flywheel to back off slightly and hang up. Has anyone else had this issue? Is the solution a different collet? If so, which collet should I run? Thanks in advance for the help.
I think that Its a collet problem... Also check if there is some grease there
