Mugen MBX6
#1291
Really Really well. I am going to put carbon shoes in my clutch to tame it a bit more. The motor is great though. Insane power, great acceleration and top end, great runtime, idles forever, holds a tune, starts on first bump. Thanks again for selling it to me. I sent a customer your way, he said hes ordering next month.
#1297
Where can one find Bess's set-up for the MBX6? Haven't received the new mag yet.
#1298
Screws
Just a curiosity guys....
How much weight are all mbx6 screws have? (more a less)
#1300
#1301
mugen clutch bell clearance
hi to all mbx6 owner,
i got a question to ask,
i put two shims and a thick spacer before tighten the screw to the crank shaft, as mention in the manual, however the end play of the clutch bell is quite alot.
how much usually the end play should be.
any input are much appreciated.
#1302
#1303
by the way do u feel tat mbx6 is bit sensitive and the front change direction very fast... can be tricky to drive it.
#1304
Registered User
suprised to hear that novaa,
ive found the mbx6 very easy to drive, i originally had issues with keeping the car from bouncing around on a blown out track as well as a few jumping issues i had with bottoming out
i solved this by changing shock oils to 45 in the front 40 in the rear, and changing the ride height and droop slightly,
are you struggling with it when going around a corner? ie when you turn into the corner and try to power out you spin out?. If so put some lighter springs on the clutch i did this and it made a massive difference
#1305
after a long hard debated I decided to get the mbx6 over the losi 8 2.0. I hope Im making the right decision. One of the main reason is that the mugen just looks more apealing. Couple questions thou, one thing I dont like about the 6 is that I have to get a 5 cell flat battery. i have 3 newer 5 cell hump packs, guess there is no way to get the hump back to work is there? Im buying it tommorrow so I will become a regular here. One more thing, Does anyone use a tuned grp in the mbx6? Just wondering how it shims with the car, on my rc8 it doesnt line up with the spur very well, clutch bell is sitting to far foward
