Losi 8ight building and setup
#1113
I run my servo saver loose.
#1114
Originally Posted by cfeight
Has anyone else had problems with steering servo horn inserts stripping out?
Replace the servo horn with a one-piece unit and don't worry about it any more. There are many choices. I used one I had laying around from my Serpent 950... just the right size.
#1115
Thank you all for your input, now my only problem is finding those elusive backup parts. My camber links are starting to get a bit sloppy and I just feel better knowing if something were to break at an away race, that I'd have a fix. Anyone know where to get a flywheel for the eight, breaking in the TL B7 made mine quite gnarly from all the pry past the pinch with a flat head that I had to do.
#1116
#1118
I wish to order the King Heads 7075 Clutch and I wish to know whis springs are most recomanded?
#1119
#1120
#1121
That was using a hair dryer getting it up to about 175 before even trying to start it and still extreme pinch, and yes the glow plug was cracked loose as well.
#1123
Hey guys, the servo spacers are ready to go.
Ultimate Products #(909)949-3000
#1124
JBRacing, i've been using 2 gold and 2 green with the king headz 7075 shoes, seems to work really well. Other people on other forums are also using that same combo with good results.
#1125
Thanks Steve.
How is the life span on them?
