Losi 8ight building and setup
#6706
Where would I find a 24T insert? I bought these:
http://www.amainhobbies.com/product_...oducts_id/7793
thinking there'd be one in there but don't see that there was.
Maybe I didn't look close enough....
#6708
#6709
just wonder does the handling will be exactly same...
#6710
http://www.teamcrc.com/crc/modules.p...prodID=7718959
#6711
In addition to the items mentioned here, CRC's "No Pop" pivot balls for the steering are a great addition. Even after a big hit, they keep the tie rod attached to the steering block. These really benefit the the truggy.
U can do the exact same thing with a set of balls and a cone washer.
#6713
HUH>.....a Grp's a Ninja...they were always somewhat tempermental to install into an 8ight...But u dont have to gring the case of the block....more like the center diff mount....or if u have the Qoncepts hope u dont have to grind too much to get a good angle on the carb...thats the only issue i know of.....why would u grind the motor mount air8 ?
#6714
Yes, you do have to dremel the one piece engine mount to get the GRP to fit. I figured I was going to dremel a 30 dollar mount vs. a 330 dollar motor... The way the GRP case is designed it would not fit in the one piece mount (the bottom of the case has fins on it), however it fit the stock Losi 8 mounts PERFECT, matched the contour of them exactly.
I did not have a problem with the diff mount, however I did find a "new" rub mark on my fuel tank from the clutch bell... I am hoping once I get the one piece engine mount in I can use the holes that shift the engine back and it will take care of that.
Dave
Dave
#6715
Howdy all! My new 8ight kit is on a FedEx plane somewhere right now and I'm trying to get prepared for the big home-coming.
I'm shopping for a simple receiver battery. Just want a regular pack, nimh...
will a common 5 cell hump pack fit?
like this:
http://www3.towerhobbies.com/cgi-bin...&I=LXMUG7&P=FR
or do I need a stick type pack?
Please excuse the ignorance; I'm coming from electric buggy and I never required an Rx pack.
Thanks in advance; can't wait to start building!
like this:
#6716
That battery will work. Welcome to a great car.
#6717
How is the front of your 8ight set up? You should be getting plenty of off-power steering with 5-7-2.
#6718
Every 8ight I've ever seen where off-power steering was a problem (not enough off power steering), it turned out to be something wrong with the front brakes where they were grabbing WAY too hard under the very slightest of application pressure.
Just a suggestion: check that the front brakes aren't doing anything strange before you go chasing a setup problem. If the brakes are working fine (front one not grabbing in a strange, non-linear way), then start looking for setup options.
#6720
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
I'm gonna try something "unconventional" for a Losi this weekend. I put in 5-5-5 to see if I can come out of the corners a little harder. I've been running 5-5-3 and like it, but the rear washes out just a little easier than I like. (I'm still learning, hope this will calm it down just a hair.) It's a 10 minute change to go back if I don't like it...
