Losi 8ight building and setup
#6677
TFC chassis report....
I ran at my LHS' track this weekend with the new Tuned Flex Chassis. I ran the same set of tires for all three heats and main that I ran the week prior. There were three different sets for the heats and the main. This way I was starting off with the exact same rubber under as close of conditions as possible on the exact same track.
All of the lap times were the same difference for the given set of tires.
These are the time differences for the two weeks.
Panthers KIIs = 31.86/30.92 Ave
Worn Proline BowTies M3 = 30.81/30.34 Ave
1 Run BowTies M3 = 30.4/29.93 Ave
I picked up a considerable amount of time over the run from the first week. I noticed the car flexing and clinging to the track 's surface and it would not get upset as easy. This meant I could push it harder and be more aggressive on the jumps and through the turns.
How much more traction did it have? Week one was fairly moist track which is odd for the conditions we normally race in. Week II was dry and everyone was complaining how slick it was. My tires were more worn for Week II's testing.
All I can say it this is a very nice improvment for an already fine and capable car.
Nice job Losi! Now fix that darn servo saver!
#6678
I just saw this one
http://rc-mushroom.com/product_info....ducts_id=15089
Whats your thoughts about it.
I don't think it wil be any good but who knows.
mzl Hellsavage
mzl Hellsavage
#6679
R/C Tech Elite Member
I just saw this one
mzl Hellsavage
mzl Hellsavage
So thats like 1/2 of the losi chassis...
Would be curious if it works as good?
#6680
I just saw this one
mzl Hellsavage
mzl Hellsavage
I wonder if that chassis from RCMushroom will be shot peened and hard ano'd like the stock Losi chassis. I'm one of those believers in "You get what you pay for"
#6684
Location: Fort Worth, Texas, USA, North America, Earth, Solar System, Milky Way Galaxy, Universe
For reliability, the aftermarket motor mount that has a "finger" running forward to prevent flex at the flywheel hole/diff hole.
For easy access to the center diff to work on it, there is a 2-piece center diff mount, but IMHO not worth $70.
#6685
aluminum Rear gearbox bearing inserts.
CVD condoms.
aluminum servo saver arm.
aluminum center diff front bearing adapter.
Depending on how it wears for you, you may consider getting the heavy duty diff cases.
Most pro setup sheets specify the 3/3 rear hingepin plate. Or you get the adjustable versions.
#6688
http://www.amainhobbies.com/product_...ducts_id/18807
http://www.amainhobbies.com/product_...oducts_id/9775
http://www.amainhobbies.com/product_...ducts_id/13549
http://www.amainhobbies.com/product_...ducts_id/10278
http://www.amainhobbies.com/product_...ducts_id/14646
http://www.amainhobbies.com/product_...ducts_id/13553
And aluminum clutch shoes.
Loctite your servo saver adjuster nut. Do this after you find the setting you like though.
Add a piece of lexan to the bottom of the battery compartment. The plastic boss for the screw will rub on the RX battery. some batteries have been broken by this.
I run all the plastic braces, no tray stiffeners, or chassis stiffeners. I don't run "flexy whatever" under the radio tray. Sometimes I leave the rear radio tray screw loose, but for the most part I forget to leave it loose and there's no issues. Just be sure to set your EPA and that the carb moves as close to a straight line as possible.
#6689
The Losi 8ight is best when driven bone stock (with a couple of exceptions)
The aluminum rear diff inserts are a must
get an aluminum steering servo arm
the quick change motor mount assembly is nice
and I also use the adjustable toe plates, front and rear.
I wouldnt waste your money on fancy aluminum braces and hardware that you dont need. all it does is make your car heavier and handle like crap.
I recently switched my set up from a "pro" set up to the Losi Race Roller "easy to drive" set up and LOVE it!!
car handles great, turns really well, and is surprisingly stable!
