tmaxx engine swap
tmaxx engine swap
am getting a tmaxx 2.5 roller this week and i have a .25 HPI motor.....i was wondering do i need to get new engine mounts, or should i be able to use the stock tmaxx mounts to set up my .25 hpi motor? i know the .25 is a larger engine so should i keep the mounts that are on my matrix(which has the hpi on it now) or can i modify the tmaxx mounts to fit this engine? HELP A BROTHER OUT TO GET
sweet....thanks.....i had trouble with the traxxas aluminum turnbuckle set for my nitro rustler not fitting properly also.....the rear turnbuckles were too long and the front ones fit the rear......sounds like traxxas aftermarket department needs to get it together
if your putting a big block on your maxx then it i highly recommended to get the big block conversion kit. it has beefier bog bones and everything. it comes with and extended chassis to make up for the lost space of the big block.
and go ahead and pony up for the Robinson racing harded almuminum and steel tranny gears. I had hell with the plastic ones after i converted my t-maxx to a big block.
And you do know that just sticking a big block in wont increase top speed right? It will deffinatly increase torque, but you will need to regear to take advantage of that torque, or else the big block will yield no results in the speed department.
