Roche Rapide F1 Evo
#676
What else is new? This is the only problem with Roche, terrible parts support, otherwise great car. This is the exact time people need parts, very little racing going on, rebuild time! So frustrating. This is why the brand won't take off, people know they can get parts for their CRC or x-ray. Rolling the dice with Roche everytime!
1. side pod links ... changed to Aluminium and no longer a problem
2. lower arm - one time
3. rear carbon hub- stud came out
I’m not an ace driver either, I do hit things!!
#677
R/C Tech Elite Member
big closeout sale on alloy Rapide F1 Evo kit now at Rapide F1 Evo USA Spec 1/10 Competition F1 Car Kit
#679
Good price. New car on the way?
#680
Updated F1 announced on Facebook.
<NEW for ROCHE Rapide F1 EVO2>
- New design graphite main chassis, lower pod plate, rear pod plate, front lower arm, caster adjust plate, top deck, chassis brace, upper pod plate, battery holder.
- New design chassis allow to adjusts the wheelbase of the front suspension in +/- 5mm.
- New design graphite top deck to improve chassis flex and chassis support when on powering. Two damper positions selectable on top deck.
- New design 7075 aluminum front bulkhead to connect upper and lower arm.
- New design 7075 aluminum servo mount. Servo position changeable for weight balance.
- New design steering arm mount, easy ackerman adjustment.
- New design camber and caster adjust plate, five difference camber angle and four angle caster angle selectable.
- New design DVS-V3 center damper. Quick rear droop adjustment.
- New design more friction side tube.
- New design motor mount and rear bulkhead. Red/Black two tones anodize.
- New design center pivot system. High / lower pivot position selectable.
- New designed independent wing mount system. Seven rear wing position selectable.
- New design o-ring type battery mounting chassis brace. 3 position forward / backward selectable.
#681
#682
Evo USA spec on sale at Roche USA. Car was so good over the last year, bought another one!
#684
I had the same problem, I used trimmed down body posts. Never happened again.
#686
Is the Xray Diff shaft a direct fit for the Roche Rapide F1 EVO? I bent the shaft and roche usa doesnt have any in stock. Is there any known direct fit ?
