Roche Rapide F1 Evo2
New car announced April 2020- shipping mid-April and available for back order now
Two kits available:
NEW for ROCHE Rapide F1 EVO2
- New design graphite main chassis, lower pod plate, rear pod plate, front lower arm, caster adjust plate, top deck, chassis brace, upper pod plate, battery holder.
- New design chassis allow to adjusts the wheelbase of the front suspension in +/- 5mm.
- New design graphite top deck to improve chassis flex and chassis support when on powering. Two damper positions selectable on top deck.
- New design 7075 aluminum front bulkhead to connect upper and lower arm.
- New design 7075 aluminum servo mount. Servo position changeable for weight balance.
- New design steering arm mount, easy ackerman adjustment.
- New design camber and caster adjust plate, five difference camber angle and four angle caster angle selectable.
- New design DVS-V3 center damper. Quick rear droop adjustment.
- New design more friction side tube.
- New design motor mount and rear bulkhead. Red/Black two tones anodize.
- New design center pivot system. High / lower pivot position selectable.
- New designed independent wing mount system. Seven rear wing position selectable.
- New design o-ring type battery mounting chassis brace. 3 position forward / backward selectable.
Two kits available:
- Carbon Chassis: Roche Rapide F1 EVO2 1/10 Competition F1 Car Kit
- Alloy Chassis: Roche Rapide F1 EVO2 1/10 Competition F1 Car Kit, USA Spec (Alum Chassis)
Two kits available for back order now. Shipment to arrive Mid-April
66Likes
