INTEGY 16X8V6
INTEGY 16X8V6
Can anyone help me how to set up my charger?I'm charging SMC3300 used battery match,every time I charge it wont charge in full 3300mah or above and always done on 3000mah or less,anyone can help and many thanks.
Here's my current set up:
1.)cell number=6
2.)battery capacity=3300
3.)phase1=6.5a
4.)phase2=4.5a
5.)phase3= I set up on 5.0a but wont go through here will done on phase2
6.)discharged=30a
7.)peak adj.=5mV/c to 30mV
8.)lock out= I put on highest
9.)charge temp.=130F
1.)cell number=6
3.)phase1=6.5a
4.)phase2=4.5a
6.)discharged=30a
You can increase the capacity setting to 4200mAh or more and the unit will cutoff later.
Also, you might want to check the software version. I think the older one is 6.0 and the newer one is 6.1. I got the upgrade IC chip from them last week. Contact their tech support guy and he will send you the upgrade IC free, his name is Bill.
3000mah? 1st cycle?
dont worry im sure on the 3rd cycle you can feed more mah in it..
wait..
are your batts new?
wait..
are your batts new?
Thanks RICKYIS300,so you mean even my battery are 3300 I can increase the capacity?will not going over heat?and you said upgarde the software and how will I know if mine is upgaraded already?and will you tell me how can I contact Bill? do you have there tell#?pls.let me know and thanks.
Thanks too TAO3S,my battery are used,and mine will done 3000mah in phase2,and will not go through to phase3,the manual said after phase2 completed,phase3 will start and your battery pack will be fully charged if there is no false peak,so it means when they stop on phase2 I experience battery false peak?Pls. let me know too and help.
bump
,Ok I'll try that but still need more advice to the PRO Racer,Thanks
Just set the mAh capacity setting higher will do the trick with v6.0, I was using 4500mAh for GP3300 and 5000mAh for IB3800. I use 5mV/cell, 130F and no problem with overcharging at all. According to Integy, the v6.1 IC fixed the 10V error also.
During the initial power-up, you'll see the version #, either 6.0 or 6.1. Go to their web site's help desk, create an account and login. Tell them the situation, your address and Bill will send you the upgrade chip v6.1. v6.1 apparently bypass the safety feature and let the unit charge beyond the max mAh setting. With v6.1, you can set 3300mAh on the unit and charge up to 3700mAh+ on phase 3. With v6.0, the unit will stop before reaching 3300mAh.
i agree with rickyis300 his suggestion will give more juice in those batts
for a used old batts 3000mah is good enough. are they matched?
Thanks Ricky for all explanation ,and yes I email them already on their website & I'm still waiting for slow respond from them ,how long did you set up the LONG LOCK CAPACITY?
And yes my battery are matched and used.
BUMP
That's weird, mine actually fried a couple months after I bought it.(16x7x6) I sent it in, they fixed it, free of charge, and sent it back pretty quickly. They were friendly and prompt, and my charger is still kicking ass almost year later... I guess mine must have 6.1, because it'll put 3700+mah in my old 3300s from a dead short.
Hi Ricky,I contacted already him(BILL)and yes he will send me the chip to upgrade to 6.1 and thanks for the tip,I would like to ask if you put the chip by your self? is it easy to put that chip inside?Pls let me know or help me how to put that chip,many thanks
