Tamiya TA07 pro
#333
The important part though is, if you took your car and only changed the caster the above would be the result.
There are lots of books that can go into the details, and obviously there are other ways in which you can change the corner entry etc.
#335
What size body will the TA07 take?
I was wondering what size body this car will take. Also what's a good set of mounted tires to get for parking lot racing?
#337
Fair enough. Since I don't have a track to drive on, understanding the minutiae of competition-grade alignment tuning wouldn't do me much good. The surfaces I drive on aren't consistent enough for super-precise alignment tuning to make a noticeable difference -- the effects of small adjustments get lost in the "background noise" of driving over bits of sand, pebbles, cracks, and dead leaves.
#338
Thanks! I thought minimum weight was 1380?
Aluminum screws? T-Works makes screws out of 7075 aluminum, they're the best aluminum screws I've ever seen. They have deep driver sockets too so they're not too easy to strip. Since you've already assembled your chassis you shouldn't need to tap the screw holes before using aluminum screws.
Isn't that weight over a hundred grams below the minimum weight for racing?
#340
Managed to TQ and throw away a win in the GT10 class during the latest FredTech race with a TA07 against a gaggle of carbon fiber cars. It was good to run it against capable competition in order to find out where improvements can be made.
+ YouTube Video | |
#341
Skillz!
That's some driving. I'm really impressed with the TA07
#344
I pick up my TA07 tomorrow and will be racing it box stock initially on medium/high bite old CRC Ozite indoors on a tight technical layout in the USGT class. I'm assuming the stock springs are going to be too soft but I'm confused as to which springs fit these shocks? The manual list the XV-01 springs as options but they don't look that great to me.
#345
