NEW XRAY T2
#4396
Originally Posted by srw_g
Hi, I want solve the rear toe issue. Which part need to replace? Rear hub or rear upright? Or just use a shim? Thanks.
Mine was about .5 deg off stock...I ended up having to change my LR upright when I broke one, and that change made mine even.
Some people reported theirs being off something like 2 degrees, though . I'm not sure if they built the car wrong (like by installing one of those lower suspension holders on backwards), hit something, had a bad chassis, or what.
#4397
Originally Posted by Nexus Racing
Rear hub or upright? Aren't those the same part .
#4398
Registered User
You dont need to go with a solid top deck. Just counter sink the stock one and never worry about it again.
I could see a solid top deck having the same issue now too, since my biggest problem is the top deck is getting pushed back into the rear bulkhead at an uneven angle. That would happen with a solid as well, but maybe to a slightly less degree.
#4399
Originally Posted by Chris Adams
I didnt mean to use washers although it might work. I meant for you to actually counter sink into the carbon fiber.
Which countersink bit are you using to countersink the top deck?
#4400
Originally Posted by 2-Bad
Considering a new car... can anyone tell me if there are any issues with the T2,
What body works best with the car?
What optional parts are needed for tuning?
What spare parts are needed for breakages (just in case)?
I'm running on rubber/ashaplt/modified....
1.Most guys are using the mazda 6,I use the stratus 3.0
2.The car is pretty much awsome right out of the box, the only things I can come up with is the multi diff which I think comes stock with any kit not purchased in the US, maybe swaybars and of course shock springs.
3.I find that if you cut your corners close and tag a rail or dot the stock caster blocks and steering knuckles are the only thing that I have broken on the car. But after purchasing the Xray wide plastic bumper I have not busted any since P-dub also makes one for the T2.
Other than that the car will win striaght out of the box
good luck.
#4401
Thanks. Mine was about .5 deg off stock,too. I haven't run the car. I just want to know this issue will impact T2's performance a lot?
In one word....NOPE!
My T2 was fast right out of the box and I have NEVER noticed any ill handling issues associated with the rear toe.
I hope this helps and enjoy your new ride!!!
#4402
My T2 was fast right out of the box and I have NEVER noticed any ill handling issues associated witht he rear toe.
Excuse for my poor English, I am a rookie from Shanghai. T2 is my first car. I am choosing the ESC, Q2C, GTX or Twister2.1?
#4405
Last edited by Jack Smash; 04-17-2006 at 06:33 PM. Reason: Jason gave correct info in following post
#4408
it shouldnt hurt it buddy.if you just run a 90 degree countersink in the 82 degree one,you can get pretty good head contact.on another note,carbide countersinks are the way to go with such an abrasive material.carbon fiber does not like to be cut like alloys,it likes to be shaved.a countersink with any sort of helical cutting edges will split the material.multi flute countersinks with multiple cutting edges are ideal for the job.they go through carbon fiber like a hot knife through butter with no lift in the material.hope this helps.
#4410
Originally Posted by Mongo
Is there a website or someplace I can check these out or see them?
