NEW XRAY T2
#4366
#4368
problems
Hey guys
I am having trouble with my T2 on rubber tyres having no rear grip
on power and off power the car was set up standard, then i changed
vitually everything to fix but nothing is working.
When i put it on the tweak station it's about 1/4 of a bubble out so
i just adjust the preload and its perfect but the car is still undrivable
ANY IDEARS CHEERS!!
ANY IDEARS CHEERS!!
#4369
Originally Posted by NOOB-SMOKE
Hey guys
ANY IDEARS CHEERS!!
ANY IDEARS CHEERS!!
Or maybe the setup from Frans Heinsbroek
And if you're still lost post your setup with Xray and ask there with a little explenations of the track you're driving for some help.
Gr. Joep
#4370
Hey guys
ANY IDEARS CHEERS!!
ANY IDEARS CHEERS!!
#4371
How durable are the T2 drive shafts? I'm putting together a spare parts list since the LHS is always hit or miss. They are priced out at $20 a piece , but seem very thin, even though there spring steel. I'm new to Xray, but have had Associated, Tamiya, Schumacher, and Hpi cars in the past and always managed to bend shafts especially running spools. Are they really that durable?
#4372
I've had my car since it was released, driveshafts are the only thing i have broken. I've actually broken 2....Both times using a spool.
HTH
HTH
#4373
The drive shafts on my FK'04 hold it for more than a year.
Rob
Rob
#4374
I've had an EVO2, FK'04, FK'05 and now a T2. Never broke a driveshaft. Only once bend one.
#4375
maby with a spool they can brake sometimes.. but I never broke one with a one-way.. (neither with a spool)...
-Hugo
-Hugo
#4377
Ok, Just about finished building the T2 (after 3 weeks lol).
Did anyone else not go with the adjustable dampers and install the "fixed" dampers? I installed the adjustables, but didnt like them (couldnt get them to constantly change). Its like they would hop or miss a click. Without the oil, it was alittle easier to tell, but once I oiled up the shocks, couldnt work it out.
Also, being new to Electric, I was adjusting my ESC and notice alittle bit of interferance, and read somewhere that I should soldier capicators to my motor to stop interference? How common is this, as I dont see many stock motors with capicators installed?
#4378
Originally Posted by THE DARKSIDE
Does the T2 use the same drive shafts as the FK'05??
#4379
Jensen's chassis squaring fixture update
Hey Guys,
I heard that production of Art's chassis squaring fixture will begin this Wednesday and Thursday and he wil be shipping them soon after that! Goodbye twaeked chassis
#4380
im running stock right now i dont put capacitor on it. and most of other racers dont put capasitor on thier stock motor..but if you wanna try you can ..anything just to keep you going..
