Tamiya TB Evo 6
#16
#17
More on the TB Evo 6 thanks to http://www.tamiyaracing.dk
84379 1/10 R/C TB EVO. 6 Chassis Kit
6 years on from its predecessor, the latest release in the high-spec TB evolution chassis series is the Evo. 6. TRF designers have given this new generation of the shaft-driven 4WD car a number of updated parts to ensure that it provides an excellent drive.
Featured Components
- One-Piece Motor Mount
- Touring Car Aluminum Short Dampers
- Carbon F/R Damper Stay & Mount
- TRF418 Suspension Arms
- Aluminum Propeller Shaft
- Full Ball Bearings
Option Parts Included
- Double Cardan Joint Shafts
- 3x32mm Alu. Turnbuckle Shaft
- 3x42mm Alu. Turnbuckle Shaft
- 5mm Alu. Ball Connector (Blue)
- 5mm Alu. Ball Nut (Blue)
- Hi-Torque Servo Saver
About the Model
- This is a 1/10 scale R/C model assembly kit.
- The chassis runs on a shaft-driven 4WD layout with horizontally-positioned motor.
- Carbon damper stays and mounts for front and rear are designed for use with aluminum short dampers
- The carbon fiber double deck provides excellent rigidity without compromising cornering ability.
- The chassis inherits the TB-04 chassis front and rear gear boxes. It features a combination of front direct drive and rear gear differential.
- Features suspension parts and aluminum suspension mounts seen on the TRF418 chassis.
Featured Components
About the Model
#18
If you can't be bothered to grind the one plastic part, just buy this:
http://www.exotekracing.com/tb04-stock-motor-adaptor/
$12 and TCS legal.
The fastest single lap at the TAMIYA America regional in gt3 was a tb04...he was around 3.20.
$12 and TCS legal.
Anyways, as a former owner of 2 EVO 5 MS cars with the Exotek lipo conversions, I was really looking forward to the 6 release. The horizontal motor mount is just not what I was wanting to see in it.
#19
#20
Here it is, the new EVO 6, what a Beauty
I think the new one is not very different from Simmi`s Racing Factory EVO Exotek 418
I Think new Bulks and Chassis, Topdeck, (Arms, Axles, Stabi all 418). Haha, my is the Future, I like
But one NEW is mine!!!!!
#22
The Exotek TB Evo 5 is still extremely competitive in 17.5 class racing. Was hoping for something similar with the Evo 6, but if Tamiya is saying its horizontal, then it makes it a less attractive offering. At least for me it does...
#24
It's interesting to me that this TB04 has more steering than any car I've ever driven. And I've driven a lot. The car is heavy. The drive train is as free as any shaft drive car. That took some serious shimming. Tamiya might be onto something.
#26
There won't be a pinion problem
#29
Let me know when you plan on coming down
