Tamiya TB Evo 6
#1804
Hi Guys,
there was a LRP Challenge Race this weekend in austria on a low grip tarmac surface. i started once again with my Exo6 in a 17,5T blinky race with 4,5 FDR .
I had to chance a few things to get the car work good for me
1.) i changed from Spool to Gear Diff in the front with 1.000.000 Oil (It was a very tricky course and just a few straights.
2.) to get more grip on the rear i went to the 6th Hole for the rear dampers.
3.) I switched from pink to green kokomo Springs in the front (very hard)
4.) Front Block changed from B to C , to get 0,5 degree angle
This helped me made it to the podium.
once again, during a 12 minutes A Main, my nervs weren't the best , that i did two mistakes each run, but thats me, and still i am happy about the performance of the xo 6 in this class !!
cheers
Flo
cheers
Flo
#1805
enclosed a Pic of the Track , the green Ford GT Car is mine
#1807
It depends on the Track . Some do , some not.
In this case , this club wasn't doing anything ;-)
But it's ok , as every driver has the same conditions ..
#1808
yeeeaaahhh the come back of tb evo
#1812
Where did you see that info? I know they are making aluminum lowers, but I can't find where they are included. I did see that the upper aluminum shock mount is different. But it only appears they changed the type of screw used to mount it to the upper bulkhead.
If the new aluminum lower bulkhead is included, that would be great, but I am sure it will also be reflected in the price.
#1813
Looks like they are in stock at Tamiya
http://www.tamiyausa.com/product/ite...oduct-id=84425
#1814
Is there a complete listing somewhere of all the available hopups for the TB04/R chassis?
