Speed Passion  F1 car - The SP1 >
Like Tree4Likes
Old 07-29-2013, 11:43 AM
  #421
BP SHADOW's Avatar
Trader Rating: 24 (100%+)
By the way we will be offering a starter package
SP1 kit
Reventon Club Spec ESC
MMM 21.5 motor
F68 body
Savox 1251 servo
Pardus P ONE tires
R1/ PowerPush 4600 70c lipo
$375+ shipping
I will be getting photos taken of the package to post on the store
BP SHADOW is offline
Old 07-29-2013, 02:39 PM
  #422
Originally Posted by simple
My SP1 with an Exotek/Tamiya front end.
what all parts do you need to install this? just the exotek kit?
sjenkins97 is offline
Old 07-29-2013, 03:30 PM
  #423
Trader Rating: 17 (100%+)
You will need the F104 lower arm and the steering hub and the typical Tamiya F104 front parts....this is the only way to keep it at 180mm wide.
Solara is offline
Old 07-29-2013, 03:36 PM
  #424
simple's Avatar
Correct, I started with the front end from an F104-X1, and added in the Exotek upper arms and graphite mount.
simple is offline
Old 07-29-2013, 03:50 PM
  #425
simple's Avatar
So the SP1 was a blast to drive the most recent night I made it to the track here in Canada. First night out I was only .5 behind Our local F1 expert's pace. Pretty pleased for a cars first setup. Only things I changed were the rear ride height (realised I was dragging the rear end for the first two qualifiers), and increased the front toe in a couple degrees. The car pushes in the middle of the corner and is a little twitchy driving out. Turn in is awesome and I have no issues with traction. The Pit tires are worth there weight in gold, and they come off clean, even with Action Hobbies Kingsville's old carpet. These tires last forever. I have lot of speed still in the car, I geared down one tooth because I felt I was over driving it, and my laptimes dropped a 10nth, but still same handling symptoms. Also, I can work with the RS because I wasn't running blinky (as per rules) but had left the VTA settings from its previous car.
As far as resilience, I only broke one part all night, and it was one of the Associated links I had swapped in for the softer SP links. Tamiya/Exotek front end is yet to be tested, I didn't hit anything, other than the occasional board snuggle. I've been driving an X1 since they came out, so once this car hit the carpet, I've been giddy ever since!
simple is offline
Old 07-29-2013, 08:35 PM
  #426
Trader Rating: 42 (100%+)
Awesome results!
I've already spied the new aluminum option parts and they look badass.
Nexus is offline
Old 07-31-2013, 08:53 AM
  #427
b20btec's Avatar
Originally Posted by Nexus
Awesome results!
let everyone else see also! I've need the caster block like yesterday.
b20btec is offline
Old 07-31-2013, 11:07 AM
  #428
Aluminum caster block for 200mm/184mm setup
Carbon reinforced plastic material parts
Aluminum steering rack
Carbon drive shaft
Aluminum motor mount with standard mounting holes ideal for silver can motor
Solara is offline
Old 07-31-2013, 12:03 PM
  #429
Korey Harbke's Avatar
Solara,
When am I able to get some of those! Particularly the aluminum steering rack, upper mount, and carbon reenforced plastic parts.
-Korey
Korey Harbke is offline
Old 07-31-2013, 02:33 PM
  #430
Originally Posted by Korey Harbke
Solara,
-Korey
I think they are being made by the mfr oversea, I am hoping middle of August in USA warehouse. There are more options then these, I haven't open up all of them to see thru them yet...
Solara is offline
Old 07-31-2013, 02:34 PM
  #431
b20btec's Avatar
Solara,
-Korey
I'm with you.
Pictures are cool but when can I buy? I need these parts!
b20btec is offline
Old 07-31-2013, 02:43 PM
  #432
robk's Avatar
Trader Rating: 22 (100%+)
Originally Posted by b20btec
I'm with you.
I hope aluminum lower suspension balls are in there too..
robk is offline
Old 08-01-2013, 07:04 AM
  #433
Jorge T's Avatar
Trader Rating: 14 (100%+)
I narrowed mine using the cam blocks facing out and now my car is 187.5mm( 1.5* camber) front 188mm rear with Pit tires on Tamiya foam wheels.
Also was able to use a servo saver with bell crank steering by placing the servo all the way back.
Jorge T is offline
Old 08-02-2013, 10:49 AM
  #434
I don't know this has been done before, but I did it by mistake a year ago but now, it seems like it is a pretty good mistake that I made.
The TCS brand rubber tires #1031 (aka Pit 571) with the F104 foam rim...the front rim/tire, I (or someone) mistakenly glued the tire the wrong side. To glue the tires correctly, the smaller diameter side of the rubber suppose to wrap around the edge of the F104 foam rims...that way, no matter how to measure it, the front tires will NEVER be 180mm per the TCS rule...it will be around 184mm the narrowest by using F104 front end...and on our SP1, it will be around 187ish mm with the 184mm setup.
But because I glued it the wrong side...now my SP1 has the true 184mm front. And if I am using the F104 fix front end, I will have 180mm front width.
However, there are some extra work to be done...the INSIDE of the tire, you will have a lot of rubbers that you have to CUT OFF...that is do-able, just need time to trim them off by using a sharp x-acto knife.
I have been using this "screw up" tires for almost 40 plus run and the traction of the PIT is just amazing...it was run 10 plus battery for indoor carpet then 30 plus run for the outdoor and traction is still plenty....I really don't know how many more runs I can do with this exact tires but I don't see any cut nor wear on it...I can guarantee it can run 40 plus more pack on it.
Solara is offline
Old 08-08-2013, 02:28 PM
  #435
R/C Tech Elite Member
JayL's Avatar
Any updates on the opton parts avail in US?
And like rob says "I hope aluminum lower suspension balls are in there too..
JayL is offline
