0.75mm wheels spacers
If you are talking about TC's , you can use any #6 washer from homedepot, steel or aluminum... I think hpi made them but they don't fit as well as the #6 flat washers....
Tamiya makes a set of washes that goes between the hex and the wheel. They come in one pack with three different sizes. Not sure the part number though.
Also 4mm flat washers will Work too. Dubro makes them . You will have to google it though....
Towerhobbies has the Dubro's and hpi(not a great fit)....
Thanks guys. After a quick search Xray (#305380) seem to be the only ones that actually make 0.75mm spacers and they come as a pack of two. The TOP and Tamiya packs come in different colours but they are all a mix of 0.5mm or 1.0mm. I can't find anything for hpi or dubro's.
The hpi and dubro's are just spacers that can fit but were not marketed for that purpose...
The problem is that those Kose spacers will make the track width 0.1mm wider than desired. And that will cost you a tenth a lap.
