Tamiya TA05 Touring Sedan
#616
Originally Posted by ttso
Another note
TRF415 steering rack won't fit TA05. The CF plate of course need to be replace (way too wide). The alum horn is in the same 2D layout BUT 2mm higher than TA05 spec.
Why 2mm higher? because there is 1.3mm extra column on chassis. If we sand it out.. it MIGHT work. I haven't decide if I going to mod it or not.
#617
Another note
#619
Originally Posted by over gear
can you use any brand of spur in the TA05?? or you have to use Tamiya spur?
#620
tcs rules
From the Tamiya USA site.
2. Any manufacturer’s electronic speed control, radio equipment, servo saver, antenna, antenna mount, pinion and spur gears, spur gear adapter, ball bearing, tire inserts are allowed
Certain classes have specific gearing rules but the GT classes are open.
Junked the .6 module for a nice 64p rock muncher.
#621
End of the day
Ok, it's almost 1AM now, today's build ending.
Something very odd need to be noted:
The diff seems too narrow to fit in bulkhead. I see at least 1mm space from pushing diff all the way left and all the way right. Checked over and over and nothing is wrong, strange problem. Same problem happened on center pully, about 1mm space from pushing pully all the way left and all the way right. Seems it need lots shim on diff...
Some comment: the chassis is too soft, the damper tower is way-too-soft. Front and rear brace also soft, so does bulkhead. The only thing that's not soft is.... motor mount. I'm going to buy Tech Racing CF set see if that make the TA05 a bit more solic. I really don't like soft chassis..
#622
Originally Posted by Turbonium
i did get a chance to run mine this weekend, at the TCS in Memphis. ran it on Sat in the club race in 19T.
first impressions.... wow. nice build, very smooth drivetrain. used the diffs at this time. basically the box setup at first....
in GT3 i ran it (shhh!) a bit, switched to blue springs f+r, as well as yellow sways, B3 tires on freshly resealed asphalt. Qual'ed 2nd, but finished 3rd overall, as well as 5th in Mini....
hehe.. you sneaky guy you! how did the diffs hold up since you ran in it in 19T? since they didnt have the rings... i thought they might start to expand.
#623
sup Chris....
didnt notice any expansion, and they seem to be a harder material than, say a TB02 stock diff. worked very smooth all weekend....
about the only thing i upgraded from kit was the 46mm cvds and TRF shocks(borrowed from another car), and i got the Aramid belts when i ordered the kit.
installed the std suspension, as the track there was 2.5" pvc, with a "Widowmaker" chicane taken at mostly full speed....
#625
sup Chris....
thats good news. maybe i can race this car in 27T with the stock diffs. thanks for the update
#626
Guys, when you use the 46mm CVD's - what wheel axles do you use? Evo IV Standard 415 ????
Cheers.
Cheers.
#628
Originally Posted by Nexus
RC TA05 High Precision Diff
Item #53849
Any chance that fits the front of a 415?
Just thought I'd ask in case someone here owns both a TA05 and 415.
Item #53849
c'mon Chris... toss in a 19! mine was a fairly old EA C2, with loads of power, seemed like.
#629
Originally Posted by Hebiki
old suspension - 46mm with OLD axles
new suspension - 48mm with NEW axles. 46mm also work.
OLD axles - 415 / 414 / Evo III etc.
Cheers.
#630
Wes, your car looked super this weekend. I gotta get me one of them for next season!
