Tamiya TA05 Touring Sedan
#5026
What hop ups do i need to start racing with this car?
#5027
what's a good gear ratio for a silver can, that's running for 45 continuous minutes?
#5028
#5029
After reading a few things about RC gear ratios, I'm a bit confused. What does a higher ratio and lower ratio give?
#5030
#5031
Higher gearing is for technical tracks and lower is for more flowing tracks right? And higher gearing will give more acceleration and vice versa?
#5033
#5034
What is the largest spur the TA-05 can run? I tried putting in an 83T spur and it didn't fit.
#5036
Get on your bike and try to start off in top (high ratio) gear. It's hard to get going and to accelerate, but once you have got it moving you can really fly
Start off in bottom (low ratio) gear and you can get going very easily and accelerate quickly, but only to the point where you literally cannot pedal any faster - time to change up a gear
The ratio you choose will depend on your motor and the track charateristics.
HTH
#5037
Originally Posted by akuhon
Hehehe ... don;t care too much.... the important thing is .... they are LE part .... only made for small qty...
Not so many as lucky as me .....
#5038
#5039
I got both my LE items on ebay.
I tried my 112, 120 and 128 46 pitch gears and they are too big. I tried my 90 tooth 64 pitch and it was too big also. If the hole was a bit bigger then the 112 would have fit with no problem. It rubs a bit at the bottom. How many TA05 spurs are out there?
#5040
