Old 08-17-2013, 04:25 AM   #4726
Bishop's Avatar
I never thought of weight under the ESC, must see if I can get a brass plate or something made up, that may be good.
Got to look at the Reflex fan mount, if only because it adds weight in the right spot, I came super close to failing a weight check today, was 4g over min limit, had a tyre blow out (and then followed by the motor), got loaned a spare motor (same as my own), but also tried some different tyres in a final run, only to walk off the drivers stand and remember I'd just changed tyres, and not re-checked the weight, got super lucky and came in 1g over legal weight.
QRCCRA
www.qrccra.org.au
www.facebook.com/englandparkraceway
www.myrcm.ch/main?pLa=en&hId[1]=org&dId[O]=4331
Bishop is offline   Reply With Quote
Old 08-17-2013, 04:25 AM   #4727
Bishop's Avatar
Oops, double post...
QRCCRA
www.qrccra.org.au
Old 08-17-2013, 06:05 AM   #4728
stro3579's Avatar
Trader Rating: 20 (100%+)
Originally Posted by grippgoat View Post
21g under rx, and 14g behind motor fan. No motor shims. About 1390g total, 2g heavy on battery side, and 50.7% rear. Close enough.
Gotta install my DCJs, and then tomorrow.
I'd post a pic, but the wiring still looks pretty shoddy. :/
-Mike
How did you determine the weight percentage?
stro3579 is offline   Reply With Quote
Old 08-17-2013, 08:07 AM   #4729
Rear / (front + rear)
-Mike
Old 08-17-2013, 02:27 PM   #4730
reg
Is it worth waiting for the 2014 to come out or will average joe not notice any difference between this one and the new,
Also if I'm running on carpet,what options should I be looking at,
reg is offline   Reply With Quote
Old 08-17-2013, 03:48 PM   #4731
B00t13g's Avatar
I would wait for the 14 indefinitely. Only options I use are hudy ecs and different springs and oils for tuning. I keep split blocks for the front and a cut top deck as tuning options.
Mackenzie Meyercord
Rc America, Xray, MOTIV, Avid, Team EAM, Apex Rc Pro Shop, Pro Spec USA, Sanwa, RSD
B00t13g is offline   Reply With Quote
Old 08-17-2013, 04:47 PM   #4732
rosko's Avatar
I want the 52 mm ecs from either spec r or rsd but one says one has a short axle and long ....which one to get
rosko is offline   Reply With Quote
Old 08-17-2013, 05:57 PM   #4733
Odin544's Avatar
Trader Rating: 93 (100%+)
So I got my 2nd T4 last week and am building it now. I also ordered the closed layshaft mounts for it. Come to find out the new kit had them already in it. Guess these will go on the other car that I know doesn't have them. Just thought I would let everyone know so they don't order them and end up with extras unnecessarily.
Originally Posted by Skiddins View Post
Probably unlikely as the mounts they are using/testing will need different holes to the current chassis.
They layshaft mounts are an option item that has been out a while. I have them on my car.
Xray - ORCA - Avid RC - MaxFX Paint
TriCitiesRC.com
Odin544 is offline   Reply With Quote
Old 08-17-2013, 06:02 PM   #4734
Thanks for the heads up!
Andrew S is offline   Reply With Quote
Old 08-17-2013, 06:54 PM   #4735
B00t13g's Avatar
Where did you order the second kit from?
Mackenzie Meyercord
Old 08-17-2013, 08:57 PM   #4736
vabroom's Avatar
Odin, where did you get the closed bulkhead from?
RC racing is still trying to prove that two solid objects can be in the same place, at the same time.
vabroom is offline   Reply With Quote
Old 08-17-2013, 10:00 PM   #4737
Odin544's Avatar
My buddy ordered them both for me. I believe he ordered through RCAmerica but I can double check with him if you guys would like. I know the T4 kits were back ordered for a bit so I had to wait a little bit for it.
TriCitiesRC.com
Old 08-18-2013, 02:37 PM   #4738
Adam B's Avatar
Has anybody ever ran ECS shafts in the rear? If so, what did you notice, if anything?
Franchise Racing Products * Fantom Racing * Pro One R/C Tires * RC America/Xray * Discount R/C Store * F1 R/C Lab * NORCAR @ The Gate
Adam B is offline   Reply With Quote
Old 08-18-2013, 02:57 PM   #4739
I am wondering why you'd want to do that?
Old 08-18-2013, 03:02 PM   #4740
Adam B's Avatar
I haven't tried it yet. I could see it maybe being a benefit if, for example, you are running high roll centers, and the diff in the lower position. Otherwise the axles are known to bind a little in this position.
Xray T3 2012 rasta_man Electric On-Road 4220 11-09-2016 01:45 PM
RC10B4/T4 Forum DerekL Electric Off-Road 14331 01-01-2016 02:18 PM
****HUGE AE T4 TRUCK TIRE SALE *** CRCDUDE R/C Items: For Sale/Trade 32 08-23-2010 08:55 AM
Tags
xray t4
