Like Tree5Likes
Old 01-17-2017, 05:43 AM   #7381
Thankyou
scytherat is offline   Reply With Quote
Old 01-17-2017, 09:21 AM   #7382
Does anyone know, if bd7 2015 alu chassis can be used on bd7 2016?
desaix is offline   Reply With Quote
Old 01-19-2017, 07:29 AM   #7383
Hey guys, I picked up a cheap sensorless Hobbywing motor and ESC from Amain. I just tried installing the motor and discovered it doesn't fit! There's nothing in the manual stating any diameter specifics. This is a 540 motor, the edges are a sharp 90deg. so it hits the upper deck, too much to lightly modify the motor or upper deck. I have a 96T spur and a 35T pinion and the space is huge.
I'm gonna have to return it. Is there a specific type of motor I need to order? I now realize I'm gonna need a motor with chamfered edges. I was hoping to do this on a budget to get my feet wet and have some fun, then go with something much nicer later on.
ponchota is offline   Reply With Quote
Old 01-19-2017, 09:14 AM   #7384
b20btec's Avatar
Most motors will have a chamfer on it. If anything it's possible to get away with a bigger spur/pinion combo. What motor turn is it anyways because you're geared at 5.48 FDR? You can run a larger spur for sure, 110/40 may be the ticket.
Soap
REFLEXRACING.NET * TEXASEOS.NET * YOKOMO
b20btec is offline   Reply With Quote
Old 01-19-2017, 09:15 AM   #7385
b20btec's Avatar
Never tried but I can check tonight for you.
Soap
Old 01-19-2017, 09:19 AM   #7386
It's a 4300KV motor. The largest pinion I have is 39T. I only have the 96T spur looks like I'll need a few larger spurs too.
Old 01-19-2017, 09:22 AM   #7387
b20btec's Avatar
A bigger combo will move everything forward to clear the upper deck.
Soap
Old 01-19-2017, 09:38 AM   #7388
Yah, I think I'll have to look at a different motor. Just my luck to pick the only motor that doesn't fit! What's a good ratio for quick and fast?
Old 01-19-2017, 10:20 AM   #7389
Thank you very much
Old 01-19-2017, 10:56 AM   #7390
b20btec's Avatar
Wish I can help, I don't deal with KV on cars except with boat motors. The gearing you currently have is suitable for a 17.5 boosted or 13.5 motor. My guess is try to get something and fit and take it from there.
Soap
Old 01-19-2017, 11:41 AM   #7391
Andy63's Avatar
That motor should work, just shim between motor and motormount. Should get some clearance. You don't need a new motor yet, try that one first.
www.andrefossto.wordpress.com|HOBBYWING |YOKOMO |HBracing |MIBOSPORT.COM |Reservdelsrc.com |Jockeli-Painting |
Andy63 is offline   Reply With Quote
Old 01-19-2017, 11:59 AM   #7392
b20btec's Avatar
forgot to mention, you can space your motor out, i've used this on my Gizmo GZ1 to push the motor out.
Spacer
Soap
Old 01-19-2017, 03:17 PM   #7393
I'll give it a shot, seems like I'll have to shim it a lot though. Def. need longer screws too.
Old 01-19-2017, 03:51 PM   #7394
Djchow85's Avatar
apologies re suggesting the 9T HW combo. I haven't owned one of those motors since my first entry level RC... and then remember about the manual noting that you need a chamfered motor.
Lancer Corolla 3 Impreza
Djchow85 is offline   Reply With Quote
Old 01-19-2017, 04:04 PM   #7395
shiston's Avatar
Default BD7-15
Hi,
With the diff rebuild kit, do I use the large black rubber o-ring to seal the case along with the paper gasket?
cheers
Hang around......we'll talk some more
shiston is offline   Reply With Quote
"TITC" THAILAND INTERNATIONAL TOURING CAR CHAMPIONSHIP 2006 John Doucakis Electric On-Road 233 03-20-2016 02:30 PM
Revolution Touring Car Championship 2005 (RTCC) SuPerDraGon Singapore R/C Racers 639 10-01-2005 03:25 AM
LRP Touring Car Masters 2005 V12 Electric On-Road 337 09-02-2005 12:43 PM
