YOKOMO Touring Car BD-7
#7096
I have a set lying around myself. Just in case...
#7097
#7098
Got a question on rear arm mounts.
I see people using a wide range of RF and RR mounts on the cars and every one seems to be running roughly 2.5* of rear toe.
Is there a math to figuring out the toe by adding or subtracting the numbers? Ive seen the sheets on Petite for figuring them out but they don't seem to really cover all the variations.
If youre all running pretty much the same rear toe what does the different mounts do for you? Feel on the track? Corner speed?
I don't quite understand the tuning behind them so hoping to learn from it.
#7099
The mounts numbering actually tells you its width: e.g. 42.0mm or 46.4mm. Since the distance between RF and RR remains the same, it's just a question of geometry/trigonometry.
Using different mounts while keeping the same toe setting simply changes the track-width, increasing or decreasing grip, steering, etc.
#7100
#7101
#7102
Smokem BD7-IIX 2.0mm Carbon Fiber Chassis
Need info. Anyone using this chassis for their bd7/bd7 14?? what difference between yokomo chassis and smokem chassis?? and is it better for bumpy low-medium grip asphalt or better stick with yokomo chassis?? ty for help
http://shop.smokem-racing.com/Smokem...sis_p_134.html
#7103
slf short shock 2 modification
Hey
Is there any modification for the slf ss2 nessecary like on the old '15 dampers? For example o-ring, bladder, piston etc?
#7104
and verify that o'rings are blacks and not red, but from some months they are already blacks as standard (BD-500G0B)
other very nice parts but absolutely not necessary are:
- B7-S5S16T Shock shaft for SLF short shock II (Titanium coat/4pcs)
- B7-S8H Lubrication hard coat pivot ball for BD7 shock cap/end (4pcs)
#7105
nothing "necessary", but if you want you can take the B7-8DF16 (Fluorine Rubber Hyper Diaphragm for SLF Short shock II), IMO they works better than the standard
Awesome, thank you. I'll take a look
at this parts.
Any oil/piston recommondations for a
small, technical and tight med bite indoor carpet track?
Regards
#7106
Pretty much every setup sheet I've seen for the BD7 seems to use the same pistons (3x 1,1mm on 2015 and older, and 4x1,1mm on 2016 shocks) and either #450 or #500 oil. Not a lot of variation going on.
#7107
with BD7 2016 my starting point is always standard pistons 4x1.1 and #500 oil
#7108
Thx a lot guys!
#7109
asphalt spec Japan Editon
Red RC announced a new BD7 2016 Japan Edition Asphalt Spec. does anyone know the part number for this?
Also Banzai Hobbies have now in PRE-ORDER two new BD7 versions, OPEN and SPORT JRM. Are these the same as the Japan Edition?
