Yokomo MR4TC-BD
#8360
There were only 555 of the SD World kits made, one which I sold almost four years ago.......They were not worth the money, Th LCG was an better move forward at that time. There are a couple Of SDW for sale in Hong Kong internet site and a some in Japan..........
There is no Definate answer when the New Yokomo Belt Drive (BD) kit will be for sale.........
You can buy a BDM from Yokomousa if they have any instock.
You can buy from RcChamps in Japan.
If the price is right you can buy mines...
I would wait if I was you.....(easier said than done). From look at the Proto it look like they are digging into some more steering for the Kit....I wish they would make the Top deck even and lift the motor mount from the lower chassis like the Tech Racing Medusa MY07
These kit is amazing in action...they are fast every where!
#8362
RcChamps? Its all in Japanese, i don't speak this language nor understand it!
#8364
Well, im glad to say im very happy with my new bdm. I wasn't able to drive it today for racing, but i did let my friend take and drive it for me. the only thing i did to the car was add my running gear, tweak and balance it. It almost set our track record it the 10.5 class!! Just a little more tweaking, and she'll be there.
Thanks Yokomo for a great product!!
#8365
I have just recently purchased a BD Grainger kit to use outdoors in the uk.
Just wondering what things do i need to change to bring it up to date with the current kits. Some things i noticed was
* CGM Steering
* Hpi 4* front c-hubs
* Newer shock bodys
Anything else i got to do to it? Would rather do it when i build it now than have to change it later.
Also what setup do i need to start on?
Craig
* CGM Steering
* Newer shock bodys
Craig
#8366
* CGM Steering
* Newer shock bodys
Craig
* CGM Steering
* Newer shock bodys
Craig
Chris's setup
No probs on advice, setup is as follows:
Front
Drive train – spool and fixed centre
Roll-bar - 1.3mm
Caster block – HB
Camber - -2
Toe angle - 0
Kick up – 0
Susp spacer – 1mm under all
Steering arm - -0 inline
Bladder – Yokomo black, no O ring no rebound
Shock - new body, 1.5mm inside, 11.6mm travel
Spring – Yokomo pro dot Pink
Oil – 600
Piston – 3 hole
Droop - 5.5 to wishbone
Top link inner – 1mm under ball
Shock upper – 2nd from inside
Shock lower – middle
Susp arm - graphite standard length
W/B - 5- -1
Ride height - 5mm
Ackermann – 2nd hole from back and CGM steering used
Rear
Roll-bar - 1.1mm
Camber - -2
Toe angle – 3.0 all inboard
Susp spacer – 0mm
Bladder – Yokomo black no O ring no rebound
Spring – Yokomo pro dot blue
Oil - 550
Piston – 3
Droop – 5 measured to wishbone
Top link inner - 0mm
Top link outer - 2mm with short silver ball
Shock upper – 2nd in
Shock lower - outer
Susp arm - graphite
W/B – 2-2
Ride height – 5
Standard chassis, standard uncut top deck, bomber belts and no rear brace. Cut motor mount and no rear post. UJ rear driveshafts, TIR fronts with Yokomo alloy spool. Alloy rear diff halves
Mazdaspeed shell
This was Chris Grainger's last set up posted by John Pape... page 268 bottom of the page.
#8367
Thanks for the setup. With the motor mount is that with the front leg machined off?
#8369
No problem,
I will just machine it off anyway. Same thing as i did to my Tc5's.
Anything else i need to do?
