Hot Bodies Cyclone
stock chassis is 2.5mm mate. For anyone else, if someone has any rear bulkheads that are not wanted, can you pm me, i need 1.
many thanks
many thanks
i only was a bit confused because towerhobbies says the cyclone has a 3mm chassis but here in europe the cyclone has also only a 2,5mm chassis
I see your point, but I aint't buying nuttin form them fellers
weird, the UK are going hardcased lipos only. Also, we all know, prototypes aren't the finished product, look at the TM E4 pics.
I agree, Max amps IS crap, its over price, and over rated crap...... While you wont be pushing a pack very hard in a touring car (compared to something bigger) They dont hold there 20C, there more in the 15-17 range..... There good packs, and Austin is a super nice guy, im not to into MA......
18T PULLEY AND REAR BELT QUESTION
Im not sure if this has already been qsked but im thinking about fitting the new 18t pulley for the rear belt only. Now my question is what will my new internal ratio be as ive increased the pulled size by 2 teeth. Also how do I work this out. Thanks for any help
Thanks!
Both pulleys on the layshaft should have the same number of teeth.
if the pullies on the layshaft are not the same the front and back tires will be rotating at diffrent speeds
16t front pulley 18t rear pulley ?
Thanks for the imput guys, I know what your saying ref having different sized pulleys on the lay shaft. Has any one tried this with the cyclone ? and what was the result. Also im sure I read on the hotbodies website that if you run just the 18t pulley to the rear it gives increased traction, so im guessing that they have tried it. Last question is if I run the 16t /18t pulley on the lay shaft
what will my internal ratio be so i can gear my motors, I know its 2.166 to the rear but is that the ratio i use to gear my motors.
Thanks every one keep the info comming
