Hot Bodies Cyclone
#3136
I guess I am one of those fast driver with great budiling skills. I broke another one of mine today. Hope the titanium ones could come out sooner.
#3137
HI GUYS THINKING ABOUT GETTING A CYCLONE WHAT DO I NEED TO GET WITH THE CAR TO BE COMPETIVE EG SPOOL WHAT SORT AND WHAT OTHER GEAR
#3138
The car is competitive right out of the box. Are you going to run on carpet or Asphalt? Rubber or foam?
If you are running outdoor Asphalt, then you might need a spool as well as a center locked pulley. If you are running foam on carpet, then you will need a diff.
You might also need different degrees of pivot block, springs, and small parts like spacer etc to fine tune your car.
I would also get the Titanium front CVD instead of using the stock Aluminum ones, and maybe change the steering knuckle or C-hub to aluminum ones for more durability.
That's pretty much it.
#3139
Or you can wait till the new Hara or Surikarn edition cyclones are released..they will come with a spool ,one ways. and all the updated parts.
#3141
hi there, ive just ran my cyclone for the first time this weekend and it was fantastic on carpet on slick tyres with just the stock setup minus the rear rollbar. but i have one problem, does anyone else have a fairly large amount of play in the rear pulley? it pulls its self straight when you rev the motor but i would like to know if any one else has had this?
thanks
thanks
#3142
thanks
thanks
#3143
That's normal...don't worry about it too much..it will center itself when running... new thinner pulleys will be released someday soon
#3144
Tech Legend
Trader Rating: 51 (100%+)
Originally Posted by kewdawg
Were you running Stock or Mod?
#3145
You heading to the Carpet Nats?
#3146
Almost half way March now. Anyone with info on the Karn Edition Cyclones yet. Really interested in the alloy layshaft top deck and the thinner pulley.
#3148
http://www.hpiracing.co.jp/ its on here the japan website both kits and it looks like they wont include aluminum toprear mount looks the same as old one graphite
#3149
I just purchased a few option parts for my Cyclone from this shop
www.rcring.com
and was very pleased with the pricing and service.
Thought you might want to have a look, especially if you are located in Europe.
Also, I am very pleased with the RW spur gear which in combination with the TiR pinion it is very quite and the mesh of the teeth between the two is perfect.
www.rcring.com
#3150
