Hot Bodies Cyclone >
Hot Bodies Cyclone
Hot Bodies Cyclone
Old 02-22-2009, 02:50 PM
  #15361
ShaunMac's Avatar
Originally Posted by deanomgwhiteguy
i mite re-build it later on when i get better electronics i got it back to normal again. my problem was that the belt was taking more spin to my right wheel then the left and when i accelerate it goes left so yer i think locktite for now
and as for the cvds im curious is the WC and the TC the same things or completly different and if the WC is a different car please send me the link thankz
When you rebuild the diff check all bearings. Including the 5x10's in the hubs and the 10x15's in the bulkheads. Make sure that they spin freely and aren't binding. Bad bearings can cause uneven power delivery and excess wear on the drivetrain.
The cvd and universal assemblies are sorta opposites of one another. See picture below.
-The WCE CVD's use the MIP design. The driveshaft captures (goes around) the axle assembly. This does offer more efficiency at extreme turning angles. Not a huge difference.
-The TC comes with universals. The axle assembly captures the driveshaft.
To this date all Cyclones share the same basic geometry. Each new version just adds new tuning features that are compatible with ALL Cyclones. No major changes have been made in 4 years. The HB Team got the design right to begin with way back in 2005. Well... all except for the diff design. It took a few years to address that issue.
ShaunMac is offline
Old 02-22-2009, 11:44 PM
  #15362
sparksy's Avatar
Trader Rating: 14 (94%+)
Mate, that's not a diff problem. As I said before, go and take the car to one of the more experienced guys to have a look over. 10 min setting up your car on a setup station and a quick check of the diff will have you sorted.
sparksy is offline
Old 02-22-2009, 11:58 PM
  #15363
rezenclowd3's Avatar
Trader Rating: 17 (100%+)
Actually both of those designs are Universals. There are no real CVDs in RC cars. We would need a Thompson coupler, which is a true CVD.
rezenclowd3 is offline
Old 02-23-2009, 01:22 AM
  #15364
RC MARKET's Avatar
RC MARKET is offline
Old 02-23-2009, 06:24 AM
  #15365
RC MARKET's Avatar
http://y-trail.de-blog.jp/maruyo/
Old 02-23-2009, 07:59 AM
  #15366
That's right.
Hi-LowBlow is offline
Old 02-23-2009, 08:35 AM
  #15367
ShaunMac's Avatar
Can you imagine the cost of manufactering a True CVD down to size for our Touring cars. You thought the XRAY ECS driveshafts were expensive!
But talk about "LUXURY"
ShaunMac is offline
Old 02-23-2009, 11:25 AM
  #15368
dizzy1's Avatar
Trader Rating: 29 (100%+)
Does anyone have the setup used at the 2008 istc worlds? I know they were running a softer setup with blues in the back but can't seem to find it. Wanted to give it a try.
dizzy1 is offline
Old 02-23-2009, 01:38 PM
  #15369
bozla's Avatar
Just got round to rebuilding my cyclone - bought it second hand a few months back. I've been trying to return it to factory spec until I came across something really odd in the manual. The previous owner had a spool arangement on the spur gear shaft, but when built to the manual, there is a one way bearing. I built it as the manual but I couldn't understand why the bearing was rotating the wrong way. But then I looked at the exploded diagram at the back, which shows the spur the other way!
bozla is offline
Old 02-23-2009, 08:45 PM
  #15370
Not only that, but the amount of added rotating mass. I prefer (in rc terms) universals to "cvds" because they seem to last longer, and in offroad, do not collect dirt and grime to wear down the components.
I think the difference you are seeing is due to manufacturing tolerances most likely with the 2 pics you shared.
Old 02-23-2009, 10:55 PM
  #15371
deanomgwhiteguy's Avatar
ok thankz for that i have just lost another pin so cvds are at the top of my to get list now
thankz for that
deanomgwhiteguy is offline
Old 02-24-2009, 08:37 AM
  #15372
ShaunMac's Avatar
thankz for that
That's odd that you keep losing pins. Are they coming out right after an impact? Is it the same universal that loses a pin or is it random? Did you loctite the set screws?
ShaunMac is offline
Old 02-24-2009, 09:11 AM
  #15373
Korey Harbke's Avatar
I agree... that is really odd. Are you using a good quality 1.5mm driver to tighten down the set screws, or a simple L type allen wrench? Try to get a hold of a quality allen driver where you can tighten the setscrew down really well without the fear of stripping the screw out.
Also, when you are building your universals, its very important to make sure the threads in the couple stay EXTREMELY clean. Any grease/oil that is in there will prevent the thread lock from ahearing the screw and coupler together, allowing it to back out fairly easily.
One last tip... If you have a dremel or a small file you can griind a flat spot on the pin itself for the setscrew to tighten onto. This allows the setscrew to have a little more grip on the pin, and also if the setscrew backs otu a tiny bit, the edges of the flatspot could possibly help retain the pin as well.
Give those a shot and see how that goes. I personally didn't see a big enough performance difference with the MIP CVD's over the stock universals. The stock universals have been great so far and I plan to continue to use them.
-Korey
Korey Harbke is offline
Old 02-24-2009, 09:13 AM
  #15374
I'm pretty sure you want a Cyclone Justin
"I got two words for ya... Come onnnn!!! Come ooooonnnnn!!!!!" -Peter Griffin
Old 02-24-2009, 09:15 AM
  #15375
STLNLST's Avatar
Trader Rating: 32 (100%+)
YGM
STLNLST is offline
