Old 04-24-2013, 09:26 PM   #496
how many of you guys used exotek chassis? what is the weight of it with the bulk heads & gearing.
how are the ball difs ? is their any dif upgrades or the stock ones work good?
TeamThibault is offline   Reply With Quote
Old 04-25-2013, 04:03 AM   #497
MaxThrottle's Avatar
Marv, we are going to use 2 sprint flux cars today to narrow down what happened to mine, thanks man!
Sprint 2 Flux w/ 2010 camaro body
41 willys Parma body, 68 primer gray Camaro beater body
65 Mustang coupe body, GT40 body
67 Vette kyosho body
MaxThrottle is offline   Reply With Quote
Old 04-25-2013, 06:07 AM   #498
I have not weighed mine with only the bulkheads and gearing attached.
I have not added ball diffs. I'm still using the stock gear diffs. The only mods I did to the diffs were to add ball bearings in place of the shaft bushings and shim the shafts to reduce slop. I have a one way diff that I might try but it probably isn't recommended for racing. You give up front brakes with it.
nubie-wan is offline   Reply With Quote
Old 04-25-2013, 06:10 AM   #499
Max, does your motor use a sensor cable? I'm not all that familiar with that model but if it does, try another one or at least check the connections. Also, make sure that you have the correct battery type programmed.
Old 04-25-2013, 07:14 AM   #500
Marv's Avatar
Max, Also check the wires from the ESC to the receiver =
HPI routes them under the upper deck too close to the lower section of the belt =
After several runs the belt will ear through the wires -
Re-Routed =
Go over the top
You might have to get an extension wire from LHS -
Marv is offline   Reply With Quote
Old 04-25-2013, 07:21 AM   #501
Marv's Avatar
Drift or Grip?
I'm running OEM diffs (out drives shimmed to remove slop)
I have a spring & shims in my front diff to tighten it some
No spring in the rear
I've tried a one way in the front =
You give up having brakes (most of them anyway)
Not really good (IMAO) on a small, tight, technical track
Not good for a noob (IMAO)
Old 04-25-2013, 06:13 PM   #502
ya out track is small and low grip carpet and very technical , race no drift. never new the dif had bushings, never taken it apart yet. what size of bearing for the dif?
thanks
Old 04-25-2013, 08:38 PM   #503
Marv's Avatar
thanks
The bushings are on the diff case out drive housings / bulk heads
2 - 5x8x2mm Bearings - IF you chose to upgrade the B070 bushings to bearings
LINK =
HPI Sprint 2 Mods - Making a silk purse from a sow's ear.
NOTE:
The rear distances from inside the axle cup to inside the diff cup are shorter in the rear of the car than the front of the car=
After the shim mod =
Using CVD's in the rear could be an issue -
TESTING A BEARING UPGRADE IN PROGRESS
Last edited by Marv; 04-30-2013 at 03:01 PM. Reason: "Any girl can be glamorous. All you have to do is stand still and look stupid." Hedy Lamarr
Old 04-26-2013, 03:57 AM   #504
Tried another ESC from Marks car and everything worked so i have a new one coming.
I had moved the ESC on top of the battery claw holder and the last few times we ran real hard and my batteries got super hot and my ESC was right there on top of it so i think the heat took out the ESC so time to find a better spot for it.
I am going to re-route the wiring, I noticed the way they did it when i first got it and didnt like it, That was one of the first things i checked due to being so close to the belt.
Thanks for the help guys!
Old 04-26-2013, 09:03 AM   #505
Marv's Avatar
Thumbs up TENNIS COURT & B-BALL COURT
Lucky me has a b-ball court & a tennis court not far from my front door -
Surfaces are not the best
But not the worst either
Tennis court is definitely the better of the two
HPI Sprint 2 Mods - Making a silk purse from a sow's ear.-0425131059.jpgHPI Sprint 2 Mods - Making a silk purse from a sow's ear.-0422131217.jpg
I just have to get jump on the future tax payers -
Or wait until they're all in school -
Last edited by Marv; 04-29-2013 at 01:12 AM. Reason: Shane Falco: "Danny! Remember what I said about red shirts in practice?"
Old 04-28-2013, 03:53 AM   #506
The tennis court looks good, put out a few cones and go through a few batteries
Old 04-28-2013, 06:04 AM   #507
WaftyCrank's Avatar
Originally Posted by Marv View Post
This thread started on 05/22/2012
50,075 views as of this post
Thanks to all the people that have contributed to this thread
AND
To all that have viewed it
AND
To those that will contribute & view it - - -
Marv
May I say a big thank you to you Marv, this thread has been invaluable to me on many occasions.
WaftyCrank is offline   Reply With Quote
Old 04-29-2013, 11:58 AM   #508
I noticed on my 4tec that the rod ends are the same as i tried them and if ne1 want they can use the rod ends that come on the 4tec to compleatly remove all slop in the fron as my 4tec has almost 0 slop will try n let every1 know need to get the parts n screws but the ones i have used compeatly removed slop in the are i need
Felix v.
Ae sc10.2, xray t4 2016 usgt,wrc f-one 016, Tamiya m05 mini
Expensive is not always faster
Scionara05 is offline   Reply With Quote
Old 04-30-2013, 03:29 AM   #509
New ESC did the trick, old one did all the right things with the led lights (green red yellow) but was not running the motor, Back on the road again, Hope to run in the parking lot after work tonight.
Old 04-30-2013, 03:05 PM   #510
Marv's Avatar
Thanks WaftyCrank -
Scionara05 = Do you have some part numbers?
Max = GLAD you're up & running again!
See if HPI will warranty that ESC for you.
Last edited by Marv; 05-01-2013 at 02:42 PM. Reason: “You only live once, but if you do it right, once is enough.” ― Mae West
Tags
hpi, sprint 2
