Xray T1FK05
#4128
Originally Posted by Chrisgt2
Well, I just picked up an FK05.....what are the fragile parts/must have hopups?
Thanks, Vogan
Thanks, Vogan
#4129
Thanks, Vogan
Thanks, Vogan
www.teamtamale.com
#4130
Originally Posted by hpipro321
wut u should get is the serpant shocks.......multi diff and battery strap and ur set
Rob
#4131
Thanks, Vogan
Thanks, Vogan
#4132
Thanks, Vogan
Thanks, Vogan
As for hop-ups, there are a lot of hop-ups that really help, but I think you notice the biggest gain when you run the entire package. Heres what I run on my car.
3.0mm chassis
Carpet top deck
Carpet front tower
Hard arms F/R
2 degree rear hubs
4.5 caster blocks (Hard)
.75 eccentrics
I believe thats it... either way that will get you real close. If you have any other questions, let me know.
#4133
Originally Posted by Bobby Flack
There aren't to many fragile parts on the car. Usual suspects for breaking are the caster/steering blocks. Personally, I avoid the aluminum parts because they are heavier and stiffer, which can take away steering. Also, instead of breaking parts, you start bending them and will add stress to other parts of the car, like the arms. Usually when the caster blocks break they just crack and your able to finish the run anyways. Shock ends and a must have in the box too, especially if your racing carpet because I guarantee you grind through the fronts at some point.
3.0mm chassis
Carpet top deck
Carpet front tower
Hard arms F/R
2 degree rear hubs
.75 eccentrics
3.0mm chassis
Carpet top deck
Carpet front tower
Hard arms F/R
2 degree rear hubs
.75 eccentrics
#4134
Not sure Brian, I haven't heard of anything but you never know.
#4135
Just got back from my lhs and saw the new xray 05 boxes. The sticker on the front said that the new kit had both a 2.5 mm and 3.0 mm chassis.
