Exotek F1R
#1653
Hey Mike - was there a reason you didn't include a rear wing mount with the Kit? I ended up buying the Tuninghaus one for adjustability and realized it won't fit without modification on the rear wings... Durrrr...
Just felt like it was something that should be included in the kit to me. Other than that - I've really enjoyed working on this car so far
#1654
They are actually available at Asiatees.com It's where I just bought mine. Great price and came quickly. (edit: wow maybe I got their last???)
#1655
To include them would then raise the price of the kits. You don't want to do that when a lot of people already have a similar part. If you need it you buy it, if you don't need it you don't
#1656
That is good news. I've been looking for a new F1 car to replace my very out dated F103 but I'll wait now. I'll check your website later in November, but hope you post an update here on RCTECH about the release date.
#1658
I realize we've moved on to the F1R2 and above versions, but I recently traded for an F1R and in its 2nd race, it won the A-main at my local club. Against my nemesis in a very fast Xray X1.
I have been running an F104V2 w/ some success, and it didn't take long for the F1R to move to the top of my 'favorite' list. I like how it hooks up off the corners a little better than my F104V2.
There's still some life left in it!
Mark
Mark
#1659
So, driving my car today i noticed a few things. Current fast car is the newest f102 car. Im a second off pacecar rotates and has a ton of turn in compared to rear stability. Pod droop is 1.5mm, ride height is 4mm. Front ifs is silver springs, thick tube lube. Down one hole from the top on the inner shock mount. Center spring is tamiya neon orange/red. Ass black side aprings. Damper tubes are crc 20k. Diff is loose. Gearing is 88/22, just swapped a 31 pinion on. Car always was run at 40/88, but everyone today is around a 4.0 fdr.
Applying throttle car would spin a bit but even after traction and tires warmed up, coming out of corners it sounds like its spinning or picking up an inner tire. Car just doesnt have drive out of the corner it seems. What is a good setup for thr f1r2 with ifs on med/high grip carpet?
#1660
Aaron
#1661
I suppose i should say, spins freely, but difficult to twist the spur if you hold both wheels-would that be considered tight? (Its been some time since i ran a pan car).
Compressing sidesprings-you suggesting i run them down with the adjuster to get them to "preload"? Keep them blacks?
#1662
I even widened the whole car just to get it a bit more planted, that helped a bit. Im trying te front shocks stood up more to take away some of that initial responsive steering and try to help deaden the front end. Might help with the rear feeling more planted
#1663
Is your battery back? Mine is forward, esc and rx behind closer to motor
#1664
idbdoug
#1665
If by short wheelbase you are talking the adjustment in the bulkheads on the rear pod, then yes im already short.
