SLAPMASTER - 1/12th MS2.2
#286
Originally posted by jumbo360
Yea I heard motor spray works but I heard from a friend that some people use lighter fluid on there foams to take out the compound so it would work as if it were brand new, never tried it though.
I've cleaned my tires religiously now after every run since I got the spanker. But definitely have not wiped down my front tires as good as my rear. I spend the same amount of time wiping rear and as to the front....maybe I'll pay more attention to wiping the fronts now.
Dom
#287
Originally posted by sparkyboyo
I cracked my 50 lap thresh hold by two laps and missed a 53 by 0.23 or summut.
Jacko
Jacko
Dom
#288
Hey don theres a slapmaster kit right cause if there is how much is it?just wondering for next year you know.
thanks,
Justin
thanks,
Justin
#289
Dom,
When my gets bad twitchy at the begining of a run I have found that if I scrub the tires on the track it helps a lot. Just wipe your tires normally in the pits then when you put the car on the track srub the fronts in the groove on the track, it has helped me in the past lately I have not been doing it because I'm lacking the steering I want. BTW you are going to have to watchout for Tom at regionals, he was turning the fast laps but was making errors, give him some more time he will be a threat.
Chad
Chad
#291
Originally posted by ChadK
Dom,
Chad
Dom,
Chad
yeah, no doubt Tom was fast.... on a TQ run only his 2nd race. Honestly, if I need to rate myself against Tom, I believe he is a better driver than I am. He got tangled up in the first couple of laps then just diced with Wes too much, if they would have worked together and not touched each other so much, I would have expected those 2 right up with me and Ellis in the main.
Dom
#292
Anyone put the slapper on asphalt yet? is it worth scrathing up that pretty tube chassis?
Chris.
Chris.
#293
I'm going to make a batch of my carbon/Carbon damper tubes and send a set to Brian to see what he thinks of them. The only issue I really have is that I use a standard size associated ball cup on the piston side for my adjustable sprung versions. This allows me to have the longest possible damped length (about 1/2" more than speedmerchant/bolink tubes). To be honest I like the standard size better as they are better quality and it is easier to find aluminum or titanium ball studs. I've been using them in my spanker for a while now to good effect. Any input you could give me Brian would be appreciated.
Chris.
Chris.
#294
Closest thing to a kit!
I know this will sound insane, but I do one car that is nearly complete that I would sell for $350. It would need a fresh set of rear bearings, rr body posts, and it has a stock Asc shock. It has a brand new IRS large ring diff with my thrust kit installed. No body, no tires. It was my promo car used for Snowbirds. It has never been on the track. I can take a picture of it if anyone is serious. I know that it is expensive, but everything was purchased at retial.
Brian; [email protected]
Chris: I would be more then happy to take a look at your latest creation. Keep in mind that my track day are very numbered for the winter.
Although I have to say, that I am doing "lots" of research right now for any future refinement!!! All of the recent brainstorming right here on rctech is not going unnoticed. In an effect, everyone is helping design this car. Keep it up!
#296
I think there Kawada tubes Jon lol
#297
Originally posted by JDXray
Hey Dom, i was looking at your Slapmaster kit, which by the way is very nice. And noticed you have nice damper tubes. I was wonder where you got those? I want to try them on my Atsushi Hara Hammer 12. Let me know, shoot me a pm if you like
Jon
Jon
Dom
#300
Re: Tubes
Originally posted by litespeed-dom
2 different types of tubes here. First one is a Bolink tubes which you can't obtain anymore, the other ones are cut-down CRC tubes that you can buy direct from Hyperdrive.
Bolink
CRC tubes
Dom
Bolink
CRC tubes
Dom
