Old 10-24-2011, 06:33 AM   #181
Originally Posted by taz00 View Post
Raced the car for the first time today. The car generates more grip than the 2011 version (at least in our track which is a very big flowing asphalt track).
So much more that I easily won my class (13,5 boosted) without having driven the car before.
Hi, can post your chassis setup and electronic components? thanks
duartev is offline   Reply With Quote
Old 10-24-2011, 07:01 AM   #182
You have got pm
taz00 is offline   Reply With Quote
Old 10-25-2011, 11:07 AM   #183
orci77's Avatar
For me it looks like the holes in the new show towers are also closer to the lower edge. This could give the TRF damper a perfect fit.
Does anybody tried this already?
Xray T3'012 + Nosram Pearl SpecRacing V2 + LRP X12 17,5T / X11 9,5T / X11 6,5T
Team Associated SC10 + Nosram Matrix Reverse + LRP X11 13,5T
3Racing F1-09 + LRP Sphere + LRP X11 17,5T
orci77 is offline   Reply With Quote
Old 10-25-2011, 12:41 PM   #184
theatriks's Avatar
Hey guys i figured i would introduce myself in this thread as im a tamiya guy who just jumped ship and has a t3 2012 on the way in the mail ...very excited....anyways i figured i would ask u guys what parts should i keep on hand as my LHS doesnt stock xray....as well as any build tips that might not be mentioned in the manual .....also i noticed a lot of u guys arent happy with the shocks on these cars .....would keeping my trf shocks be a good idea or are they not compatible.
Rob
theatriks is offline   Reply With Quote
Old 10-25-2011, 02:45 PM   #185
CraigM's Avatar
Trader Rating: 34 (100%+)
Rob
Welcome, youll certainly find the X-ray more durable to crashes and wear and tear than the tamiya. As such you don't need many parts at all, in a year running the car all I've broken was one knuckle and one top deck, and both were not ordinary crashes. The main thing I use is driveshaft blades for the rear diff, and it's a good idea to keep spares of the screws that hold the lower suspension mounts onto the suspension bridges because they can bend in crashes.
The kits also go together really well, check for clearance of the top deck as you may have to sand the ends slightly to so they don't touch the bulkhead clamps, also check the clamps don't rock on the eccentric diff bearing holders, if they do you can shim them or sand the diff holder down to ensure you get good life out of the bearings.
Shocks are a personal preference, the plastic ones can be a bit fiddly to get right. Tamiyas bolt on OK with the tamiya hardware but would bind on the old shock towers. A better bet is to fit X-ray shock caps and bottoms, I posted a how to in the t3'11 thread on this
www.facebook.com/mcpheerc
CraigM is offline   Reply With Quote
Old 10-25-2011, 11:53 PM   #186
nerdling's Avatar
Rob
I'll add a couple of things to Craigs post. I've been racing Xray since 2001 and can confirm that are very reliable.
Grab yourself a pair of rear hubs and front knuckles. These seems to suffer the most when you run out of talent. I have seen a couple of rear belts snap (racing mod) since the indroduction of gear diffs.
I have run the plastic shocks in the past. They are pretty good but don't waste your time the adjustable pistons, these seem to 'self adjust', go with the convertional pistons and regular maintenacne and you will be fine. That said I'm running some TRF's on my indoor car (the extra length is usfull for low diamater foams) and XRAY Alloy shocks on my out door car possibly the best shocks I have ever used
Mark.
--XRAY--NOSRAM--PROTOFORM--MUCHMORE--
www.teamxray.com -- www.hudy.net -- www.hobbyexpress.com.au
nerdling is offline   Reply With Quote
Old 10-26-2011, 05:28 AM   #187
kinga's Avatar
Trader Rating: 15 (100%+)
Mark.
+1 on the xray ALU shocks for outdoor asphalt. Found them much more compliant on large bumpy outdoor asphalt. MUCH MUCH easier to build than the plastic shocks too, dont seem to suffer quite so much when the bladders swell, as they will after one or two oil changes. I cant rate the ALU shocks highly enough, found them on par with the TRF shocks, really nice equipment to work with. They also come with multiple pistons with different sized holes from 0.9 to1.2mm.
When you read setup sheets from the pros with "1.1mm" pistons listed, these are from the ALU shocks, they provide less "pack" than the TRF and standard xray pistons with .9mm piston holes, which is why they work better on bumpy open asphalt.
kinga is offline   Reply With Quote
Old 10-26-2011, 07:58 AM   #188
M-Technic's Avatar
RCAmerica is due to have the 2012 kits in next week.
RCAmerica | Xray | Hudy | Radiopost | Speed Passion USA | Trinity | P3 Graphics
M-Technic is offline   Reply With Quote
Old 10-26-2011, 07:58 AM   #189
theatriks's Avatar
Thanks alot guys ....would anybody know whos a good canadian supplier for xray parts?
Old 10-26-2011, 08:04 AM   #190
ChrisP's Avatar
Send a message via Yahoo to ChrisP
Contact [email protected] with your location for a list of nearby dealers
There are many local hobby shops and several Canadian mail-order shops who have access to and/or stock Xray parts.
TeamXray.com
Team Tekin
ChrisP is offline   Reply With Quote
Old 10-26-2011, 08:06 AM   #191
theatriks's Avatar
OK thanks im glad theres lots of support.
Old 10-26-2011, 08:07 AM   #192
locked's Avatar
http://canwestrcshop.net
I haven't ordered from them yet, but they seem to be THE store for xray stuff in Canada.
Dave Locke
Team PerformanceHobbies.ca | ORCA RC | Bodies by Brandon | Team Meeting
XRAY T4'15 x2 | XRAY XB4 | XRAY XB8E | XRAY XB8
locked is offline   Reply With Quote
Old 10-26-2011, 09:07 AM   #193
theatriks's Avatar
Hey thanks ya i checked them out and thats where im getting my t3 actually and they have a full line of parts and its in canada so thats awesome ....i just thought maybe there was some more suppliers at my end of the country .
Old 10-26-2011, 09:29 AM   #194
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
where's your end?
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is online now   Reply With Quote
Old 10-26-2011, 10:11 AM   #195
locked's Avatar
He's in Ottawa. I'm in Toronto. I know Lou's Speedway near London stocks XRAY parts, but Lou doesn't have an online store. I don't know any shops nearby that stock xray. Most of the hobby shops around here are completely out of touch with the on-road racing scene and the few that are exceptions to this, have very limited stock.
nexusracing.com down in Georgia has a great selection of xray stuff and they tend to fill out shipping waybills so you probably won't get charged any brokerage (e.g. gift $30), but they charge a flat rate of $30 for shipping to Canada, so you'd want to put together a reasonably large order to make it more worthwhile. Last time I ordered from them, I got the order within a couple of business days.
Dave Locke
Xray T3 2011 entitymugenmtx Electric On-Road 4150 05-19-2014 12:53 PM
Xray T3 2011 New in Box olhipster1 R/C Items: For Sale/Trade 19 08-04-2011 05:27 AM
XRAY T3 2012 bila nk keluar? bravolous Malaysian R/C Racers 8 06-16-2011 11:58 PM
Xray T3 nitro rat Australia For Sale/Trade 22 09-19-2010 03:11 PM
