SpeedMerchant Rev.7
#151
I'm going to buy a new 12th scale before Christmas but I'm trying to decide which one I want. There are only 2 I'm deciding over the Rev. 7 and the other is an American based car also. The last 12th car I raced was a Rev. 4.5 and I loved that car, fast with any setup and it could be driven hard.
I am wondering is the Rev. 7 the same way? How does the new inline setup work verus the old layout? What is the big diffrence with the new liner tweak spring setup? Can this car be driven very hard, I can't drive a car that has to be driven easy I have a tendancy to push things and I'm kinda edgy at times.
Thanks for any imput, I just want to buy a US made car.
#152
Thanks for the tip. Car went really well. I ran it as kit settings all day just to get the hang of the car. I just need to find a bit more initial steering so Im going to have a look at caster settings. Rear end was planted though so its got real potential.
Tim
#153
Hey guys I have a question.
I'm running 43mm front tyres and a 1.5mm ride height spacer gives me 3.8mm ride height. So my question is how are you making 3mm with small tyres? This is using the Old Skool front end.
Tim
Tim
#155
With the machined old school front end it requires no shims, and I barely squeak 3mm. I think it was 39mm was the absolute smallest I could run.
#158
Here is a latest configuration of my test car. Allows for quick change of the steering ink akerman, as well a a totally different weight bias. I have also gone to a receiver pack (for various reasons) but mainly to balance the car better, and keep the wiring cleaner...
What's your setup?
#162
Does that mean front ends will be available with different camber and caster settings?
#163
#165
I have also started testing the Parma speed8 HD body. I seems to be a very nice alternative to the AMR and a much better choice than the sketchy Black art body...
