Carpet maintenance ?
Just wondered if there is anything maintenance wise we should be doing with our carpets. They are used for about 4 hours a week and then rolled and kept off the ground till rolled out again. We run additive with rubber and foam tyres each week. I can't remember it ever being hoovered so was wondering if it makes a difference at all ?
Hello Racers, First i would change the layout quite often as to get bite all over the rug and not to wear it out. Second don't all ways run the same way. let the rug breathe some. next i would vacuum the rug before you roll it up every time. this way nothing gets in the back of carpet and makes lumps in your track as in foam chunks and body clips.screws, the more often you roll it up the harder it is going to be to get flat, starts to get ripples in it. and all ways roll on a pole, and try not to roll any crease's in it. Hope this helps, Ron H,
6" diameter PVC pipe is better (if you can find it).
Cheers guys. We run a different layout each week and the carpets are used in different parts each week (Randomly) they are also rolled carefully on 4" pipes so its maybe just a hoover that they need.
sono tube
We use (approximately) 10 inch diameter "Sonotube" to roll our 7 rolls of carpet about 3 times a month. Sonotube is used as a concrete form so it is very durable yet surprisingly not terribly heavy. It still takes some effort to keep the ripples out but if rolled carefully it has worked well. We also use some velcro on the tubes to help guide us initially when starting the roll. Hope that helps.
Jake D.
http://www.sonotube.com/
Jake D.
