Team Associated TC4
#6211
Hey everyone with a FT TC4......I was thinking about getting a TC4 but heard it had a lot of slop in the steering. So I called associated and they said they had never heard that problem nor were having the problem themselves. Anyone that has found that steering slop problem on their FT TC4 please respond so I cas see how many people are having it or if its just a few. Thanks
#6212
I too noticed that the ballcup was slight touching the driveshaft. I dremeled the ballcup down slightly and now there is no rubbing at full lock.
#6213
Batteries...... and more questions......
Will the FT-TC4 accept the GP3700's??? Or do I have to file away the cahssis to make the batteries fit snugly?
Does the FT-TC4 come with a battery brace or do we just tape the batteries?? If so, is there an option to use a battery brace?
Will the input shafts of the TC3 fit the FT-TC4? I still have some bnew lightweight ones.
Thanks!!!
Thanks!!!
#6214
Thanks!!!
Thanks!!!
#6215
Originally Posted by tc3 racer sc
no battry braces you hve to use tape
Or make a battery brace out of the warpspeed tc3 chassis
#6216
Originally Posted by BlackKat
Joey, As soon as you get to race it, please e-mail me some feedback. I'm probably gonna get a 3Racing chassis (looks nice and the price is right) Could you tell me how much weight the chassis conversion took off the car?
(Anyone want to trade my TC4 for a TAMIYA EVO4? Email me if interested and I will tell you what else comes with the TC4. No electrics)
#6217
Thanks!!!
Thanks!!!
#6218
Originally Posted by DawgMeat1
If you look back on the previous page you will see my pics of the TC4, I have 3800's in my car
Could you please PM or post how you did the slots? Is that manual or with a dremel?
Thanks!! Lem
#6221
LEM2: There are holes provided for a battery brace, but no brace in the kit. Yes the layshafts are the same as the TC3/4 shafts. My lightweight layshafts dropped right in. The biggest change is how the rear shaft is shimmed between the spur and the cup for the main shaft. The single thick spacer is ditched for more adjustable thinner spacers.
I had a battery jump out on me today and stretch into an accordion. Apparently i didnt file the tape slots enough to avoid cutting the tape. I did get four batteries out of the same piece, so i guess i shouldnt complain. The car was smooth and responsive today with that setup i posted a few pages back. The only changes were no spine, and Jaco Plaid/Purple tires. Just the four chassis posts for stiffness. I noted no rubbing of the ballcup on the mainshaft, but it is very close.
- DaveW
- DaveW
#6222
hey guys i have a question,,, what would be good gearing for a 19t motor on my tc4? I am using 64 pitch, i ahve been experimenting here and there with what i have, 96, 100 tooth spurs and from 28-40 tooth pinions and just cant seem to find the right one. Any advice on a good base to start from?
#6223
#6224
the track i run on is roughly 50x100 ft. ,, im using that same motor that you mentioned.
#6225
I really don't know what all the fuss about too much slop in the TC4 steering is all about.
I have built or worked on virtually every make and type of car in the last 12 years and have yet to come across one without slop. The TC4 has no more than most. I know it doesn't look good, but a bit of slop doesn't effect the performance.
Indeed some manufacturers actually tell you, in the car's instructions, not to try and remove the slop as it will make the car wander more on the straights.
