Team Associated TC4
Man, where can I get a CF chassis for TC4? Diggity is out of *all* the aluminum pieces. I have the FT motor mount but can't get aluminum DC4 servo mounts......
Unless someone knows of a substitute floating servo mount?
The diggity chassis has been updated to use the TC7 servo mount. I was the first customer to get it
Solution to DCJ pin slop
Drilled out brass tubing in steps starting at 1.7mm and increasing .10mm till 2mm, seems tight enough on the pin, but I will add solder as extra insurance
Took a few tries before i was pleased with the result but the mount fits pretty awesome 😎
Kinda new to the TC4. Picked up a club racer and have upgrades already on the way! Question is I bought a set of Tc7.1 DCVs and the steering blocks. With the exception of dremeling the caster block is there anything else that needs to be done or should I use tc7.1 caster blocks as well?
One thing you may want to check on your cars is whether or not your driveshaft and yokes are spinning true, because if they are off the vibration can eat a lot of power.
Kinda new at this, but I just ordered a tc4 club racer for vta, and a hobbywing 25.5. Trying to get to a final drive of 4.0. Will a 78 spur and 50 pinion in 64p fit? If not what spur and pinion in 64p will get me closest to 4.0?
