Old 12-08-2015, 04:39 PM   #6856
CamLS's Avatar
I've yet to get a V3/V4 motor mount for my Eryxx 2.0 so I need a spur with larger openings like the Durango ones. Serpent spurs work well after 3 of the hole are reamed with a body post reamer.
Thanks for the info.
CamLS is offline   Reply With Quote
Old 12-10-2015, 02:55 PM   #6857
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
Hi,
I have just picked up a couple of S411's for me and my son, I have raced TC previously with TCXX and Spec R so it will be good to compare chassis.....
Sworkz EVO II/O.S/Futaba
Sworkz BE1 EVO II/Hobbywing/Protek
Sworkz S350T US edition/O.S/Futaba
Taffyjnr5 is offline   Reply With Quote
Old 12-11-2015, 07:16 AM   #6858
dan_vector's Avatar
Trader Rating: 27 (100%+)
Welcome to the brand!! You'll love the cars... Enjoy!
Serpent Viper 977e EVO2, Serpent Viper 988 GP, Serpent Project 4x, Serpent 811T-TE Truggy, Serpent 811e 2.1, Serpent SRX2-MH, Serpent SRX-2 RM, Serpent SRX-4, Serpent F110-SF2, Serpent F180, Serpent 748 Natrix WC, Serpent Cobra GT 3.1, Serpent SRX8, Serpent S811 2.2, Baja 5B Flux, Atomic AMZ 1/27th, Schumacher GT12 SS.
Sanwa, Ielasi Tuned Novarossi Racing Engines, Tekin, Hobbywing, Muchmore.
dan_vector is offline   Reply With Quote
Old 12-13-2015, 08:36 AM   #6859
Paulie Bee's Avatar
Default c hubs
4 degree are stock ... correct?
Are the 2,6 degree C hubs available in stock plastic or only aluminum?
Thank You...
SERPENT AMERICA & DESOTO RACING
VP POWERMASTER RACING FUELS, Dean Isaac Paint Schemes,
PT RC Racing Oils
Paulie Bee is offline   Reply With Quote
Old 12-13-2015, 09:24 AM   #6860
CamLS's Avatar
Yes, stock is 4 and the 2 and 6 are in aluminum only.
Old 12-13-2015, 11:03 PM   #6861
swerv512's Avatar
Today was an awesome day for me and the Eryx 2.0. Car handled better than a slot car. It was totally hooked up on a tight high bite asphalt track. Amazing feeling when this car is in the groove. Just sending credit where it's due to all of you who consistently give feedback and support. You guys are my factory support lol.
swerv512 is offline   Reply With Quote
Old 12-14-2015, 07:51 AM   #6862
The FastFred's Avatar
You can use these old parts with a little grinding and they work fantastic. I hear the AL bends upon impact so it's not reliable.
Need to pay attention to hub entering into a-arm so you get easy and full droop. A little relief at hub so drive train does not hit and ream out the A-arm for the larger pin. I use a drill bit for the pin size and all works great.
have photos if interested.
PS anyone have the old parts and want to sell them Im buying!
#401085 - hub
#401152 - pin
# 401035 - steel pin
The FastFred is offline   Reply With Quote
Old 12-14-2015, 08:52 AM   #6863
Johnny Wishbone's Avatar
Default C-Hubs
Paul says that Yokomo c-hubs will work in the current car with some slight modification. Not sure if its the pin or the steering hub that needs to be modified. It also looks like the TC 6.2 chubs will work with some slight modification, not sure about the durability on these though. (Same pin)
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 12-14-2015, 09:10 AM   #6864
swerv512's Avatar
On the topic... My front c-hub is also unbearably tight. I'm not sure if the pin hole needs reaming out or if I need to sand some material off. I notice when setting the car up that the arms are super free before installing the c-hub on the front. Once installed the movement is very tight.... Going to take a tad bit of material off around where the c-hub pin to see if that helps.
Old 12-14-2015, 09:20 AM   #6865
More information please. Is this when its installed with everything attached, Steering hub, DJC, camber links and steering linkage, or just the c-hub into the arm?
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 12-14-2015, 09:54 AM   #6866
swerv512's Avatar
Gets tight once c-hub goes onto front arm, nothing else is attached at that point. The arms move up and down super free when only the front arms are attached. The moment I attach the c-hub the friction appears. The pins are very tight going in, but that is normal on all the arm hinge pins, but the balls in the mounts keep them friction-free somehow.
Edit: it feels like the arms only get friction-free once the weight of the wheels and tires are attached. When setting droop I have to push the arm down to make sure the set screw is touching the chassis. In comparison, the rear arm and upright are friction free all the time.
Old 12-14-2015, 10:08 AM   #6867
johnny anyone will x-ray fit. They have a good selection of plastics.
Old 12-14-2015, 11:42 AM   #6868
Arms should drop freely with no added weight of other components, if they dont then you have some bind somewhere in your assembly. When I assemble arms onto the chassis, once they are close to tightening the suspension mount screws, I will give them a small tap with the handle end of the wrench just to make sure everything seats in properly and there is no bind. Tighten the screws as normal and check, if there is bind loosen one of the screws slightly and give the arm a tap and tighten. There can be no bind in the arms or you will be chasing handling ghosts. The c-hub should also be free to rotate, if not some fitting may be required. What ever you do, DO NOT ream the arms, as the pins are suppose to rotate in the suspension block bushings.
If I remember correctly I think the Xray pin is larger than what we use.
Here is another tip for ill handling cars. Ive had a couple guys run their cars and have had really strange handling issues, most notable, the car wants to oversteer on exit. After going threw all the basic checks for chassis adjustments the issue continues. Both times now, it has turned out to be weak servo savers causing the cars to not come back to center. So if you have one of these weird issues, check your servo saver, it may be the culprit. I prefer the xray servo saver or the Durango HD servo saver, both of these are very similar and I will use the xray springs in the durango plastic to make a nice long horn servo saver when required.
Gary Lanzer
Team VBC HK
Team R1WURKS
EMR Factory LLC
AWESOME Graphics
Old 12-15-2015, 01:21 AM   #6869
Benzaah's Avatar
Trader Rating: 21 (96%+)
With regards to the arm and chub binding, the quality of the latest plastics is much better than what we used to deal with. It's only Every now and then you get either an arm or a c hub that's tight, like the plastic didn't set properly and it's slightly warped and binds the pin into the arm. unfortunately sounds like you have both. I've tried a few different ways to fix this over the years and if you sand the outside or ream the entire hole in the C hub it creates uneven surfaces and it will be free but will have more slop.
I've found that if you get your body reamer and lightly ream both sides of the c hub and then give the arm a very light sand just around the inside edge of the arm as pictured you can eliminate most if not all bind. I also ream the steering knuckles before I install them as I like those to be super free too.
AERCCC - ARCR - RRCSA
Adelaide RC
Walter Rc Hobby
Benzaah is offline   Reply With Quote
Old 12-15-2015, 10:58 PM   #6870
swerv512's Avatar
I ever so slightly sanded some material from the c-hub and it no longer binds against the a-arm. Thanks for the tips.
BTW... the Durango HD servo saver works great and fits without any modification.
Batu Kawan Rc Track Tongga Malaysian R/C Racers 10418 06-28-2016 10:34 PM
DRCW Raceway Chesapeake, VA // Asphalt / Indoor Off Road / Outdoor Off Road stiltskin Racing Forum 10278 11-14-2014 06:39 AM
