Serpent S411
#6706
Received my V3 motor mount today. It's a nice bit of alloy. I noticed the vertical plate it attaches to blocks access to the lower mounting holes. Can the bit I've outlined be safely removed? I notice on the revision Gary posted above, that whole section appears deleted.
EDIT: Too late. It's done!
#6708
I took a little plastic off the servo saver.
#6710
Awesome
#6712
Does the Gear-diff revision-set (#804173) fit in the Geardiff housing V3 (#401598) ? Is it the same parts as Geardiff V3 composite (#401592) ?
Ok , now to really confuse things .... will Geardiff revision set (#401371) fit in the V3 housing ?
I am just looking for the most bullet proof system to stop chewing through gears .
thanks .
thanks .
#6713
Been at the german nats and talking to the cars developer about the gear diff. He recommended to use all shims according to the manual(V3 Diff). But you can use a slightly thicker shim which covers the outdrive seal (the big diameter shim). It should be 0,2mm thickness in the kit but he said you can use 0,3mm to be sure.
#6714
R/C Tech Elite Member
I'm piecing together a used V1 kit and I've got a Tekin Redline 17.5 to go in it.
I need to order some pinion gears to go with the 96 tooth 64P spur I got with it but what final gear ratio should I be looking for with this motor?
What if I want to change to a 10.5 motor or something in that range?
I only have a couple 8th scale offroad cars right now so I know nothing about how much max RPM increases as turn count decreases. Is there a chart somewhere? I have the Serpent spreadsheet with final drive ratios for different spur/pinion combos but don't know what I should be looking for.
Thanks,
Chris
Thanks,
Chris
#6715
Thanks,
Chris
Thanks,
Chris
#6716
For 17.5 blinky you probably want to start with an FDR of 4.0 which would be 48t pinion on the 96t 64dp spur you have fitted. You may have trouble getting that size of pinion on the V1 motor mount. Not certain about that but I know it didn't fit in the v2 mount.
If you went to 10.5 blinky you'd probably want to start around 5.5 FDR which would be a 38t pinion on the 96t spur.
If your running boost however the above would change. Boosted usually runs higher FDR's than blinky.
Use the serpent gear ratio chart to calculate FDR.
#6717
#6718
If you use the v2 motormount, a 40t 64dp Pinion is the biggest possible if you want to screw the motor tight through the spur gear.
#6720
Rack
Hi,
I am updating some parts on my S411 Sports.
The steering rack is just flat plate with lots of slop, wondering what is the difference with the optional steering rack 401465 and the 401395 steering rack, is one better ???
Cheers
Cheers
