Like Tree16Likes
Serpent S411
Old 07-01-2012, 06:59 AM
  #3826
Originally Posted by TimPotter
I took a look at my car.. for those of you that are interested... this is for a very high traction track. My next setting change was to be bars and diff oil. The car is VERY balanced and reactive. Not too edgy or hard to drive. This was for Blinky 17.5
I did not have chance to try the setup with yellow/yellow, or gray/gray yet.
Standard TE Chassis topdeck and plastics.
Front
1.5 Camber
0.5 toe out
1.5 FF Block
1.0 FR Block
No Shim outer camber link -4mm inside in the innner hole
450 Exceed Oil 3 hole piston Black Spring
Hole #3 on the tower - outer on the arm
2mm front, 2mm rear spacers - wheelbase
1mm rollcenter shim
5mm ride height
1mm droop over ride height
1.4 Bar
Rear
1.5 Camber
0 RF Block
3.0 RR Block
2mm shim outer camber link -3mm inside in the innner hole
400 Exceed Oil 3 hole piston Black Spring
Hole #5 on the tower - outer on the arm
4mm front, 2mm rear spacers - wheelbase
.5mm rollcenter shims
5.5mm ride height
2mm droop over ride height
1.4 Bar
Solaris Tires/Speed 6 Body
Thanks TIM. Did you use spool in front and what rear diff oil did you settle with?
JETT is offline
Old 07-01-2012, 10:47 AM
  #3827
Default Martin Crisp
Martin joined Serpent Team at the end of last year, I think.
And he is a gonner already?!
Well that marriage didn't last very long!
How come?
Kensei is offline
Old 07-01-2012, 11:02 AM
  #3828
cwoods34's Avatar
How come?
Just wasn't feeling it anymore..... If he's like the rest of us, the bug will start biting again soon
cwoods34 is offline
Old 07-01-2012, 11:46 AM
  #3829
Johnny Wishbone's Avatar
How come?
From what we have heard, Martin has taken on a new project that has taken him away from RC for a while...........nothing to do with the car.
Johnny Wishbone is offline
Old 07-01-2012, 01:52 PM
  #3830
Pattojnr's Avatar
Trader Rating: 19 (100%+)
here is a different view. i must say thanks to Rodney for sitting at the end of the straight, to have a car come at you at over 110k/hr just 2 mts from you is pretty ballsy.
http://www.youtube.com/watch?v=M5H_1...ature=youtu.be
Pattojnr is offline
Old 07-01-2012, 02:46 PM
  #3831
TimPotter's Avatar
Trader Rating: 15 (100%+)
Spool front 800wt in diff
TimPotter is offline
Old 07-02-2012, 10:27 AM
  #3832
Manual says 1,200 cst. What track conditions does Serpent mean here?
What best to use on
- low traction tarmac
- medium traction tarmac
How about this XRay info? Any good for the S411?
LOW-TRACTION
600cst
700cst
800cst
Note : softer oil increases rear traction,
harder oil increases on-power steering.
HIGH-TRACTION
900cst
1000cst
2000cst
What pinion gears best to use? (the ones on the Serpent website are too big for me)
Are the spur gears on the Serpent website any good?
Any alternatives?
Would these fit? http://www.rc-mushroom.com/advanced_...sort=1a&page=1
Do I need any special tools, that are not in the kit, to build this car?
Kensei is offline
Old 07-02-2012, 07:14 PM
  #3833
gearhead_22's Avatar
[quote=Johnny Wishbone;10915772]I have not found a Serpent pivot ball with a longer shank. I changed out my outer pivot for a xray link and ball that allows you to use a screw so you can get more thread into the meat of the rear upright.[/qu
I solved my problem, I put the v2 steering rack and took the ball ends from the v1 steering system and a couple of 6mm grubs screws and put the ballends on top with plenty of thread in the rear up rights
gearhead_22 is offline
Old 07-02-2012, 07:18 PM
  #3834
now with the v2 steering system what does adding spacers to move the akerman foward or leave it back do?
Old 07-02-2012, 07:20 PM
  #3835
TimPotter's Avatar
The X-ray info is good. I would start with 600 on low traction. Get the car close, then work on the diff. Not sure who makes the serpent gears , but they are nice, I have not had any noticeable problems with them.
No special tools needed
What best to use on
LOW-TRACTION
600cst
700cst
800cst
HIGH-TRACTION
900cst
1000cst
2000cst
Any alternatives?
Old 07-03-2012, 07:57 AM
  #3836
Thanks for the info.
What brand of pinion gears best to use on this car?
(the ones on the Serpent website are too big for me. Need FDR from 3.5 to 4.5)
So the Serpent spurs are good.
Any alternatives?
Kensei is offline
Old 07-03-2012, 08:09 AM
  #3837
orcadigital's Avatar
Trader Rating: 61 (100%+)
Any alternatives?
Spur or pinion? Get a spur in the 92-96 range and you will be running pinions between 45-55, all which fit. I am running a Core RC spur right now (RW Xray) and have used Xray and Serpent in the past. All are quality gears. Running a 94 spur currently in VTA (96 in 17.5 blinky TC). Should have no problem getting into your FDR range.
For pinions, I am using CRC and PRS. Both work well, the CRC seem lighter, both super quiet. This is all 64 pitch of course.
orcadigital is offline
Old 07-03-2012, 10:45 AM
  #3838
Sorry my bad, but I forgot to mention it has to be 48 pitch.
Any comments on that matter?
Thanks again.
Kensei is offline
Old 07-04-2012, 04:57 AM
  #3839
TryHard's Avatar
Originally Posted by Ryan Maker
Serpent Factory and working to fix this problem as we speak, they will be bringing out a ball stud that is 2-3mm longer.
With the bladders, the easiest way to build the shocks for me was to insert the bladder and screw the top on even with no oil. This beds the bladder into the shock top, then unscrew it and fill it with oil and screw it back on. If you put the bladder on top of the body then try and screw the top on - it's a nightmare.
I found the best feeling shock was when I drilled 1mm hole in the shock top. For some reason on our shocks you still get rebound - even with the hole. But you don't have to bleed as much oil out to get the desired rebound, hence better feeling and longer lasting shocks.
Hope this helps a bit, if anyone has any questions I'd be more than happy to help!
Ryan.
I got to run my car this past weekend, and I can't agree with Ryan more.
As I noted earlier, I had a real struggle building the shocks initially, and switched out the bladders before running. During the first run, I also drilled the top, and again that improved the car... quite a lot, with a very different (better!) feeling on track. Bladders are TAM53576 for those interested.
Anyway, back to the first run.... Having been pretty busy and not had a lot of opportunity to race recently, I headed into the weekend with limited preperation, and making it slightly harder by running mod, and at a new track too... deep end anyone
Anyway, I made up a list of stuff to run through during the day. This consisted mostly of major changes, and leaving the geometry alone, mainly as the geometry is something that doesn't seem to change too much over a number of setups.
First up was the V1 vs V2 (one-piece) motor mount.. felt that the car was more locked in and consistent with the V2, so left that on the car for the rest of the day.
Next up was a load of Diff changes, as I had built the diff as kit to start with (2gear, 1.2K), and felt this was a little soft, as the car was a bit unstable into the turns, and seemingly diffing out a bit on power. From those runs, I settled on 2gears with 2K oil as the prefered combo. The 4gear diff I also tried with 1.2K, but this was very hard and inconsistent to drive, very snappy on low throttle. Maybe 1000wt would have been better with the four gear, but it didn't feel great on the bench, so maybe needs a bit of work still.
Last on the list (well, not quite, as the shock change was last of all as I didn't have time to do that between rounds!) was playing with the rear roll bar positions. Having started out with kit (1.4mm, inside mount), feeling that the car was a bit too unstable during quick direction changes, I tried the 1.2mm bar on the outside mount to make it more linear and generally softer. This worked well to settle the rear down, too well in fact as the car then started to generate a on power push. To resolve this, moved the rear shock up one hole to 5 from 4. One thing nice to feel was that even this small change was felt on track, and did make a difference.
Overall, the day went really well, very happy with were the car ended up. Plenty still to come from it (and the driver), but every run learnt something, and every change I could feel on track. Also very impressed with the durability of the car, only issue I had all day was a rear CVD pin falling out after the grub screw came loose. Replaced both the rear's with TOP pins, that have a ground flat on them, and loctite, and that was the sum of the days problems. No issues with losing settings, no loose bits, no tweak issues... just a solid, easy and relaxing days racing. Just great really
Looking forward to running the car some more.
Regards
Ed
Final Setup - EC - Landsborough Interclub
TryHard is offline
Old 07-04-2012, 07:59 AM
  #3840
Is it really necessary to drill the shock top to get the shocks to work well?
Kensei is offline
