Team Corally RDX Touring Car
#4036
Where is a good place (on line shop) to get this car?
#4037
#4040
Well, after deciding to no longer fight with my JRXS on high traction carpet with foam tires in Mod, I've decided to get an RDX. Everyone I see switching to one always go faster, and the car looks easy to drive. A few questions though, for running Mod on foams.
Any reason to run 75 arms instead of the Xtra hard arms? I'd think the stiffer the arms, the better.
Also, what's the deal with lowering the shock towers? How/where do you drill new holes? Also, I heard about new 'lowering blocks', that might make drilling not necessary? Can anyone clarify that?
Can't wait to get the car and try it out!
#4041
The 75 arms are the extra hard ones. Lowering the tower alllows the body to be slammed. Hopefully there will be towers out soon already drilled. Make the new hole so the top camber hole lines up with the bottom row. I think it is 3mm.The only lower blocks are sold as a option for roll centers, if that is what you are talking about. You can not drill them to make them lower.
#4043
Originally Posted by miamifanatic
hello all i just finished with my carpet spec and it seems to be alot of play in the hinge pins. I put the car together as the instructions said just wondering should i shim them or what? The play is in the arms and the hubs
One super thin brass motor shim should do the trick. Thats how my car is set-up. As you probably know-if it binds up the arm at all with the shim-find a thinner one or go without.
#4045
Hey guys. I was at my local carpet track yesterday and clicked off some goodtimes using a 19T motor. My car is new and the one thing I noticed was a particular noise coming from the drivetrain. Its sounded like the belt was skipping when I got back on throttle after a turn. I went to tightned down the belt tensioner and it stil had the clicking noise. Has anybody experienced this ?
BTW: this car is freakin DIALED !!!!!!!!!!
#4047
Trader Rating: 20 (100%+)
belt skipping?? make sure your diffs arent slipping.. or the front wheels rubbing the front lower spring perches..
#4048
Originally Posted by Advil
H8R POWER! LOL
Faster than your old car? More stable? Easier to drive? More overall grip? Where do you think the car is better than your old car? Inquiring minds want to know....
More stable: yes. The RDX tranisitions quicker going through the chicane at the track. The corner speed is a little quicker than my previous car. Advil, remember we talked about throttling through an apex and keeping its line ??? This car will enable you to do that when you prepare to enter any kind of corner before you hit the apex !! Alot of it has to do with set-up also.
Easier to drive: It feels the same as my FK05. The major difference is acceleration and entering / exiting corners.
Overall grip: With more ajustability on the RDX, this car has more grip than my FK05. On my FK05, there are only 4 areas of adjustments ( 2 on the shock towers to adjust rollcenter ONLY and 2 on the rear hub carriers ). On my RDX, there is a total 12 adjustments ( 4 camber / 4 rollcenter ajustments on the shocktower and 4 on the rear hub carrier ).
Rightnow, im having this "clicking" issue with my car. I posted the thread above if anybody can help me. Even though my front belt is fairly new, im thinking about changing the belt to a newer one to see if the noise goes away.
#4049
