Xray T3 2011
#797
I do not know if its just me. I find that the servo saver that comes with the T3'11 is not very durable. For mine, it fails to work well after about 8 runs and after that, the steering does not return.
Secondly, the upper deck is a little bit fragile. For some reason, my upper deck sheared off near the recess for the bearing holding the spur adapter. From my knowledge, I have not crashed my car at all throughout my runs. Hence, it is a little strange. It might be caused by me running the super soft flex setup.
#799
The 2011!!! anything has to be an improvement over the 2010!!!
#800
#802
Offcourse, its been optimized.
Some stuff better some worse.
#803
#804
I'm pretty sure I assembled mine right
edit: found http://forum.teamxray.com/viewtopic.php?f=8&t=10892
#806
No servo saver problems here, or top deck, and I've tried to put it through the wall a few times, lol. Must be luck of the hits I guess.
#809
#810
Where do you drill the hole? Right by the eye hole?
