Like Tree2Likes
Xray T3 2011
Old 06-05-2011, 07:39 PM
  #2296
mok
mok's Avatar
Originally Posted by John_S
I agree with chris that a car with some understeer will wear the tyres out extremely quickly. Post you setup so we can have a look and try and diagnose the issue
i've attached the setup i'm currently using to this post...
info about the track..
- bumpy, quite a few cracks
- 10 degree banked sweeper exiting the straight
- 60m straight, top speed about 110kmh
here's a link to an image of the track..
http://www.rctech.net/forum/attachme...ma_highres.jpg
and here's the track on nearmap..
http://www.nearmap.com/[email protected]&nmd=20110420
-Mark
mok is offline
Old 06-05-2011, 08:04 PM
  #2297
Korey Harbke's Avatar
Hello Everyone!
I just posted up my setup from the Reedy Race on Xray's setup sheet database. It's a pretty solid and easy to drive setup with a push. My std asphalt setup I developed this last weekend is actually a lot better overall, but I figured I would post both for everyone to see. Happy Racing!
-Korey
Korey Harbke is offline
Old 06-05-2011, 08:47 PM
  #2298
Trader Rating: 32 (100%+)
No linky for the lazy!? gawd.
Originally Posted by Korey Harbke
Hello Everyone!
-Korey
racenut123 is offline
Old 06-05-2011, 09:08 PM
  #2299
Suspended
-Mark
Wow, that is a funky setup you have there. I recommend going back to a spool in the front and starting all over with the roll center at the arms. Kick up at the front is just asking for more weight transfer. To compensate, you went to the 3.2 springs but i really do not think that is the way to go. Try flat all the way around with l1 l2 2 hole front, 3 hole rear and go from there. I cant imagine it being bad.
Chris Adams is offline
Old 06-05-2011, 09:17 PM
  #2300
It's good for you . Gives your finger some exercise :P
Old 06-05-2011, 09:31 PM
  #2301
spring71's Avatar
Smile
We have indoor rc track & hobby shop in chino CA.
Spec R Gear Diffs and Universals are in stock.
Click Here to see Spec R products.
Click Here to visit the parts store
Please visit www.tqrcracing.com for more information.
spring71 is offline
Old 06-05-2011, 10:17 PM
  #2302
mok
mok's Avatar
oops, the setup sheet is not showing the diffs i am running atm..
-- front is a spool, rear is a gear diff with 2000wt
funny thing is, while the setup may be "funky".. its currently holding the track record over 5mins
mok is offline
Old 06-05-2011, 10:26 PM
  #2303
miccal's Avatar
Trader Rating: 23 (100%+)
Oh snap!
miccal is offline
Old 06-05-2011, 10:35 PM
  #2304
Suspended
You didn't seem content with wearing through your front tires at a fast rate so i was trying to help. Track record may not mean much depending on where you race haha
Old 06-05-2011, 10:39 PM
  #2305
mok
mok's Avatar
Originally Posted by miccal
Oh snap!
lol.. you shush you :P
yeah, i'm not content with wearing through my front tyres at a faster rate than the rears..
aside from that, one of the other things i dont like is it develops a bit of an on-power push through the chicanes on the track i linked before..
thanks and keep the suggestions coming, i'll prob end up trying them all!
*edit* ps. you are right, the kickup should probably go.. that has been something i never can decide what i like
mok is offline
Old 06-06-2011, 12:13 AM
  #2306
CraigM's Avatar
Trader Rating: 34 (100%+)
the on power push is from the 4mm front droop
I think you should go back to kit with the h front roll centres. Otherwise, I'll have a good setup you can try after NSW titles
CraigM is offline
Old 06-06-2011, 12:25 AM
  #2307
Here's my latest sheet for my local track, I still find the front's wear more and it pushes. Needs more turn in, I think. I also find the back can sometimes get loose on and off power but not that often.
http://forum.teamxray.com/xform/inde...&setup=t3_2011
S.A.W is offline
Old 06-06-2011, 02:43 AM
  #2308
CraigM's Avatar
Have you tried different goop? I find Rhienard only works on a few tracks, and it can make the car really squirrelly everywhere else.
I would stand the rear shocks back up to kit and go to 2 deg of rear camber to settle the rear down, then go back to 3.0 or 2.8 front spring to get the front end back, and put the shocks back down a hole on the tower. To get better initial you can go back to 1mm shim on the C-hub or add a bit of antidive, 0.5mm shim under the suspension block behind the spool is a good way to achieve this.
CraigM is offline
Old 06-06-2011, 04:00 AM
  #2309
CraigM's Avatar
Originally Posted by EAMotorsports
Yes please post some pics! Id like to see how yours is setup. Mine was just like Hag's and couldnt get it right.
Thanks!
EA
Here are the pics of my servo mod. The hardware is all tamiya, this makes a difference because the ball nut is probably 1-2mm higher than an xray one would be and that stops the link hitting the rack at full lock, of course you could just as easily shim an xray one. The shim on the servo horn is 2.5mm, and the servo is about 1mm in from the chassis edge - this is important, at first I had it flush with the edge and I couldn't get full lock.
Attached Thumbnails Xray T3 2011-imag0191.jpg   Xray T3 2011-imag0192.jpg   Xray T3 2011-imag0193.jpg   Xray T3 2011-imag0195.jpg   Xray T3 2011-imag0197.jpg
CraigM is offline
Old 06-06-2011, 05:03 AM
  #2310
Thanks.
Yes tried other additive I normally use the CS stuff. Only reason I use 3.2 's on front is because my car always seems to be loose into a corner/chicane off power. I've also been on old tyres which doesn't help when there grained on the front
S.A.W is offline
